I'm trying to make a RC controller with an Arduino Uno using examples i found on the internet and tutorials but I've this problem i can't seem to solve. Namely: when I try to add a fourth channel the compiler gives a few errors (I'll post them below). So I was wondering if you guys could help me out a bit with these errors and maybe other things I've done wrong.
Here's my code
#include <PinChangeInt.h>
#define THROTTLE_IN_PIN 8
#define YAW_IN_PIN 9
#define ROLL_IN_PIN 10
#define PITCH_IN_PIN 11
#define THROTTLE_FLAG 1
#define YAW_FLAG 2
#define ROLL_FLAG 4
#define PITCH_FLAG 5
volatile uint16_t bUpdateFlagsShared;
volatile uint16_t unThrottleInShared;
volatile uint16_t unYawInShared;
volatile uint16_t unRollInShared;
volatile uint16_t unPitchInShared;
uint32_t ulThrottleStart;
uint32_t ulYawStart;
uint32_t ulRollStart;
uint32_t ulPitchStart;
Serial.println("RC controller");
PCintPort::attachInterrupt(THROTTLE_IN_PIN, calcThrottle,CHANGE);
PCintPort::attachInterrupt(YAW_IN_PIN, calcYaw,CHANGE);
PCintPort::attachInterrupt(ROLL_IN_PIN, calcRoll,CHANGE);
PCintPort::attachInterrupt(PITCH_IN_PIN, calcPitch,CHANGE);
static uint16_t unThrottleIn;
static uint16_t unYawIn;
static uint16_t unRollIn;
static uint16_t unPitchIn;
static uint16_t bUpdateFlags;
if(bUpdateFlagsShared)
noInterrupts();
bUpdateFlags = bUpdateFlagsShared;
if(bUpdateFlags & THROTTLE_FLAG)
unThrottleIn = unThrottleInShared;
if(bUpdateFlags & YAW_FLAG)
unYawIn = unYawInShared;
if(bUpdateFlags & ROLL_FLAG)
unRollIn = unRollInShared;
if(bUpdateFlags & PITCH_FLAG)
unPitchIn = unPitchShared;
bUpdateFlagsShared = 0;
interrupts();
Serial.println(unThrottleIn);
bUpdateFlags = 0;
void calcThrottle()
if(digitalRead(THROTTLE_IN_PIN) == HIGH)
ulThrottleStart = micros();
unThrottleInShared = (uint16_t)(micros() - ulThrottleStart);
bUpdateFlagsShared |= THROTTLE_FLAG;
void calcYaw()
if(digitalRead(YAW_IN_PIN) == HIGH)
ulYawStart = micros();
unYawInShared = (uint16_t)(micros() - ulYawStart);
bUpdateFlagsShared |= YAW_FLAG;
void calcRoll()
if(digitalRead(ROLL_IN_PIN) == HIGH)
ulRollStart = micros();
unRollInShared = (uint16_t)(micros() - ulRollStart);
bUpdateFlagsShared |= ROLL_FLAG;
void calcPitch()
if(digitalRead(PITCH_IN_PIN) == HIGH)
ulPitchStart = micros();
unPitchInShared = (uint16_t)(micros() - ulPitchStart);
bUpdateFlagsShared |= PITCH_FLAG;
And here are the errors:
sketch_sep12a.ino: In function 'void setup()':
sketch_sep12a:42: error: 'calcPitch' was not declared in this scope
sketch_sep12a.ino: In function 'void loop()':
sketch_sep12a:86: error: 'unPitchShared' was not declared in this scope
sketch_sep12a.ino: At global scope:
sketch_sep12a:164: error: expected initializer before 'if'
sketch_sep12a:168: error: expected unqualified-id before 'else'
sketch_sep12a:173: error: expected declaration before '}' token
My apologies if i'm asking something stupid
Greetings,
