Hello to everyone,
I just moved my project from Arduino nano to Arduino SAMD21 mini.
I used pwm32library and servo.h library :
#include <Servo32.h>
#include <Motor32.h>
Servo32 servo1(5);
Motor32 motor1(2);
const int StartEscPin=13;
const int LedAccPin=10;
void setup(){
pinMode(StartEscPin,INPUT);
pinMode(LedAccPin, OUTPUT);
pwm32_init(); // Call this once.
void loop(){
if(digitalRead(StartEscPin) == HIGH )
digitalWrite(LedAccPin, HIGH);
servo1.set(1500); // 50hz
motor1.set(1000); // 490hz
if(digitalRead(StartEscPin) == LOW){
digitalWrite(LedAccPin, LOW);
motor1.set(1000);
#include <Servo.h>
#include <Wire.h>
Servo ESC; // create servo object to control the ESC
const int EscPin=2;
//int potValue; // value from the analog pin
pinMode(EscPin, OUTPUT);
//ESC.write(1000);
// Attach the ESC on pin 9
ESC.attach(EscPin,1000,2000);
// potValue = analogRead(A0); // reads the value of the potentiometer (value between 0 and 1023)
// potValue = map(potValue, 0, 1023, 0, 180); // scale it to use it with the servo library (value between 0 and 180)
if(digitalRead(StartEscPin) == HIGH ){
ESC.write(2000); // Send the signal to the ESC
if(digitalRead(StartEscPin) == LOW ){
ESC.write(1000); // Send the signal to the ESC
Normally ESC when is well connected make 2 sounds coming from BLDC: first sound of three notes and last sound, after a certaint time, a long acute one sound note that meanthe ESC is ready. This happen with the project made with Nano using Varspeedservo.h and everything work well.
But with Zero this do not happen. I can hear only first three notes sound and the ESC do not work.
Any has some suggestion? Thank you in advance.
