raschemmel:
What are using to read the values from the receiver ? Are you aware that is PPM ?
If you're reading from separate pins, it's PWM.
You'd only be decoding PPM (which is just a stream of PWM pulses), if you'd broken out the connection between the receiver and decoder on a single pin.
