Hi All, Here is my program to send data to a FS1000A transmitter.
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
int v=(25);
// Transmitter is connected to Arduino Pin #10
mySwitch.enableTransmit(10);
mySwitch.send(10236577,24);// runs once to open or shut gate gate is 10236577,24
delay(1000); // send pulse too fast if delay not added
void loop() { // if this not included sketch wont work
Serial.println(v);
The code I obtained from my receiver mx-rm-5v and using my remote, gate opening lock which has a receiver and relay. This is not working. Everything was working ok previously using a txc1 transmitter. But when I came back to it a few days later it wasn't working anymore. I then checked the specs on the txc1 and its max voltage was 3v. I had been using 5v from arduino. So I assume it must have failed.
Another strange thing from the sketch that previously worked was that it was longer than 24 digits and nothing like the code I am getting now which in binary is 100111000011001010100001 which I assume to be the decimal number 10236577.
Can anyone suggest why this later transmitter doesn't work? I have soldered a 25 cm wire to the module. The distance to the gate from the transmitter would be I suppose 30 meters.
