RC-Switch Using sample programs to receive / send codes - Pulselength fails
am using the example ReceiveDemo_Simple and SendDemo.
I added a line to ReceieveDemo_Simple to display the Pulse Length.
When I run it it gives:
Received 5506355 / 24bit Protocol: 1 / Delay: 185 microseconds
Received 5506355 / 24bit Protocol: 1 / Delay: 186 microseconds
I then looked at the SendDemo and it does not specify either Protocol or Pulselength. I believe that it defaults to Protocol of 1 and Pulselength of 200. However it works as standard with the defaults.
I made a small change to set the Protocol to 1 and the Pulselength to 185 - I got these from the ReceveDemo displayed above.
i.e. I set this:
mySwitch.setProtocol(1,185);
The code does NOT now turn on or off the plug.
I changed the value from 185 up through to 194 and it still didn't work.
at 195 it started to work.
mySwitch.setProtocol(1,195);
I then bumped it up 1 at a time up through 224 at which point it stopped working again.
So my questions are:
why would the ReceiveDemo report a Pulselength of 185 and why doesn't that same value not then work in the SendDemo?
Should I ignore setting Pulselength entirely and simply let it default? Or is that asking for trouble?
Does the Pulselength default vary based on the Protocol? in other works if I get a different Protocol value back from the ReceiveDemo should I set that Protocol value correctly on the Send but not touch the PulseLength?
Sorry if these are dumb questions.
