Hoping someone can point me in the right direction as i have been googling and searching the forum for far too long
I am wanting to convert an old rc transmitter to 2.4ghz , i have a RF module that takes in a PPM signal , so i am looking for a code that will take the 8 inputs that are available ( 6 pots and 2 switches) and convert there signals into a single PPM stream that then will go to the RF module
Im sure someone else has already done this somewhere but for some reason i can not find it anywhere
If anyone knows of such code and where its available please let me know
i wouldnt know how to add the inputs ect to that code ,
was hoping for a ready done code , there are loads that use the NRF modules but cant find any that output a PPM signal for use with a regular RC JR style RF module
Your code would receive values over the radio, convert them to servo control pulse lengths (typically 1000 to 2000), and put them into this array:
/*this array holds the servo values for the ppm signal
change theese values in your code (usually servo values move between 1000 and 2000)*/
int ppm[CHANNEL_NUMBER];
I am curious why you do not want to use the existing PPM signal from your old RC transmitter, disconnect it from it's HF circuit and connect it to the PPM input of your 4.4GHz module. At least that's what I did with an old transmitter last year. No Arduino required.
the transmitter i got is a basic toy one with no PPM signal , just has a blob chip , i gutted the board out of it and want to turn the case into a useful transmitter
