RC transmitting?
Hey guys! I'm pretty new to the microcontroller scene. Been programming for a little while though.
I found this old RC helicopter recently and I was trying to see if I could interface it with arduino. Not by directly connecting the arduino to the helicopter, but to the remote. I opened it up, and found the antenna. I tried to get a read from it using the pulsein technique, but the voltage seemed too low (an analog read was bellow 200 usually). So I fiddled around and still have not found a way to "figure out" the remote.
So how could I get my arduino to use the remotes antenna to transmit the same frequencies, but based on when I hit keyboard buttons? (I already got the whole keyboard --> arduino part down with processing though.)
Thanks!
The signal at the antenna has been modulated - the Arduino cannot work at these sort of frequencies, and cannot demodulate to PPM.
You need to find the signal from the encoder before it enters the transmitter section.
AWOL:
Okay. This helps a lot, but I might still need some more help here. I could wire my arduino directly to the buttons, but that would require more wires and soldering and whatnot. What does the encoder or transmitter section look like?
Here is a picture of what the board looks like. It has four buttons that control direction, a and the three wires on the right control the throttle. The black thing in the center is just the switch. The things that I don't know are the two cubish things on the close-left side, and the shiny-er one to the right of them.
It says TIC 13,5975MF on it. But I couldn't find any datasheet for it.
At what point to I want to 'intercept' the frequency?
http://img864.imageshack.us/i/sany0398a.jpg/
I managed to do it by connecting the arduino to each button individually, but I would prefer to do it with just one wire. Anyone have any ideas?
Check out this link:
Hope this helps
Thanks! That actually helps me with another project, but by one wire- I mean right to the spot before encoding the signal, not to the buttons.
