RC Vehicle With Xbee Does Not Move
Hello everyone, i am new to arduino and i am trying to make an RC car.
I have used arduino UNO, Xbee S1, Xbee Shield v03 and Motor Driver L293D shield.
So the problem i am facing is that when i insert motor driver shield’s pin directly to the arduino it works properly when i send a command using serial monitor, i mean the motors perform as they are supposed to.
Whereas when i stack up the motor driver shield on Xbee shield and insert the Xbee shield on the Arduino UNO then there’s no response from motor when i send the command using Serial monitor on Arduino IDE.
This is the code of my vehicle, its pretty basic but as i am new so i am having some problem in understanding what i am doing wrong.
#include <AFMotor.h>
#include <SoftwareSerial.h>
AF_DCMotor motor1(1);
AF_DCMotor motor3(3);
char xbee;
  pinMode(0,INPUT);
  analogReference(DEFAULT);
  motor1.setSpeed(255);
  motor3.setSpeed(255);
  Stop();
  xbee=Serial.read();
if(xbee=='F')
 forward();
if(xbee=='B')
 backward();
if(xbee=='L')
 left();
if(xbee=='R')
 right();
if(xbee=='S')
 Stop();
void forward()
     motor1.run(FORWARD);
void backward()
     motor1.run(BACKWARD);
void left()
     motor3.run(BACKWARD);
void right()
    motor3.run(FORWARD);
void Stop()
  motor1.run(RELEASE);
  motor3.run(RELEASE);
Any help is highly appreciated. Thankyou.
Most likely, stacking the shields leads to a wiring problem. Post links to the exact shields.
