Hello everyone!
It's been a couple of days that I've been trying to make the RC522 work on my Arduino uno WiFi Rev2, but with no success.
I connected the RFID module like this
without connecting the SDA pin because it is not specified in the above image.
Then I used the MFRC522.h library but it gives me several errors at compile time. I'll show you the example code that I'm using and then the errors that I get.
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 10 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
#define NEW_UID {0xDE, 0xAD, 0xBE, 0xEF}
MFRC522::MIFARE_Key key;
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522 card
Serial.println(F("Warning: this example overwrites the UID of your UID changeable card, use with care!"));
for (byte i = 0; i < 6; i++) {
key.keyByte[i] = 0xFF;
if ( ! mfrc522.PICC_IsNewCardPresent() || ! mfrc522.PICC_ReadCardSerial() ) {
delay(50);
return;
Serial.print(F("Card UID:"));
for (byte i = 0; i < mfrc522.uid.size; i++) {
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
byte newUid[] = NEW_UID;
if ( mfrc522.MIFARE_SetUid(newUid, (byte)4, true) ) {
Serial.println(F("Wrote new UID to card."));
mfrc522.PICC_HaltA();
return;
Serial.println(F("New UID and contents:"));
mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
delay(2000);
In file included from /home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp:7:0:
/home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp: In static member function 'static const __FlashStringHelper* MFRC522::GetStatusCodeName(MFRC522::StatusCode)':
/home/mauro/.arduino15/packages/arduino/hardware/megaavr/1.8.5/cores/arduino/Arduino.h:30:20: error: cannot convert 'const char*' to 'const __FlashStringHelper*' in return
#define F(str) (str)
/home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp:1282:29: note: in expansion of macro 'F'
case STATUS_OK: return F("Success.");
/home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp:1283:31: note: in expansion of macro 'F'
case STATUS_ERROR: return F("Error in communication.");
/home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp:1284:34: note: in expansion of macro 'F'
case STATUS_COLLISION: return F("Collission detected.");
/home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp:1285:32: note: in expansion of macro 'F'
case STATUS_TIMEOUT: return F("Timeout in communication.");
/home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp:1286:32: note: in expansion of macro 'F'
case STATUS_NO_ROOM: return F("A buffer is not big enough.");
/home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp:1287:38: note: in expansion of macro 'F'
case STATUS_INTERNAL_ERROR: return F("Internal error in the code. Should not happen.");
/home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp:1288:32: note: in expansion of macro 'F'
case STATUS_INVALID: return F("Invalid argument.");
/home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp:1289:34: note: in expansion of macro 'F'
case STATUS_CRC_WRONG: return F("The CRC_A does not match.");
/home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp:1290:35: note: in expansion of macro 'F'
case STATUS_MIFARE_NACK: return F("A MIFARE PICC responded with NAK.");
/home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp:1291:23: error: cannot convert 'const char*' to 'const __FlashStringHelper*' in return
default: return "Unknown error");
/home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp:1291:38: error: expected ';' before ')' token
/home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp:1291:38: error: expected primary-expression before ')' token
/home/mauro/Arduino/libraries/MFRC522/src/MFRC522.cpp: In static member function 'static const __FlashStringHelper* MFRC522::PICC_GetTypeName(MFRC522::PICC_Type)':
Multiple libraries were found for "SPI.h"
Used: /home/mauro/.arduino15/packages/arduino/hardware/megaavr/1.8.5/libraries/SPI
Multiple libraries were found for "MFRC522.h"
Used: /home/mauro/Arduino/libraries/MFRC522
exit status 1
Error compiling for board Arduino Uno WiFi Rev2.
I don't really know how to solve it, please someone help me, I'm going crazy
