RC522 TFT Animation
Hallo zusammen, hab das Problem einen Progressbar abspielen zu lassen , ich finde aber den Fehler nicht.Die Animation erscheint ganz kurz statt 5 sek.
#include <SPI.h>
#include <MFRC522.h>
#include <TFT_eSPI.h>
TFT_eSPI tft = TFT_eSPI();
MFRC522 mfrc522(21, 22);
MFRC522::MIFARE_Key key;
byte nuidPICC[4];
bool isProgress = false;
unsigned long previousMillis = 0;
const long interval = 5000;
int reading = 0;
#define GREEN2RED   4
SPI.begin();
mfrc522.PCD_Init();
tft.begin();
tft.setRotation(1);
tft.fillScreen(TFT_BLACK);
 if (mfrc522.PICC_IsNewCardPresent() && mfrc522.PICC_ReadCardSerial() ) {
   if(printHex(mfrc522.uid.uidByte, mfrc522.uid.size)=="a2afd183"){
     Serial.println(printHex(mfrc522.uid.uidByte, mfrc522.uid.size));
	 isProgress = true; // animation starten
    mfrc522.PICC_HaltA();
//---- animation progressbar     --------------
 if(isProgress){
   if (currentMillis - previousMillis >= interval) {
    linearMeter(reading, 10, 180, 10, 35, 3, 22, GREEN2RED);
    reading++;
    if (reading > 22) { reading = 0;}
  isProgress=false;
//---------      function  progressbar  ---------
uint16_t rainbowColor(uint8_t spectrum)
  spectrum = spectrum%192;
  uint8_t red   = 0;
  uint8_t green = 0;
  uint8_t blue  = 0;
  uint8_t sector = spectrum >> 5;
  uint8_t amplit = spectrum & 0x1F;
  switch (sector)
    case 0:
      red   = 0x1F;
      green = amplit;
      blue  = 0;
    case 1:
      red   = 0x1F - amplit;
      green = 0x1F;
      blue  = 0;
    case 2:
      red   = 0;
      green = 0x1F;
      blue  = amplit;
    case 3:
      red   = 0;
      green = 0x1F - amplit;
      blue  = 0x1F;
    case 4:
      red   = amplit;
      green = 0;
      blue  = 0x1F;
    case 5:
      red   = 0x1F;
      green = 0;
      blue  = 0x1F - amplit;
  return red << 11 | green << 6 | blue;
// val =  reading to show (range is 0 to n)
// x, y = position of top left corner
// w, h = width and height of a single bar
// g    = pixel gap to next bar (can be 0)
// n    = number of segments
// s    = colour scheme
void linearMeter(int val, int x, int y, int w, int h, int g, int n, byte s)
  int colour = TFT_BLUE;
  for (int b = 1; b <= n; b++) {
    if (val > 0 && b <= val) {
      switch (s) {
        case 0: colour = TFT_RED; break;
        case 1: colour = TFT_GREEN; break;
        case 2: colour = TFT_BLUE; break;
        case 3: colour = rainbowColor(map(b, 0, n, 127,   0)); break;
        case 4: colour = rainbowColor(map(b, 0, n,  63,   0)); break;
        case 5: colour = rainbowColor(map(b, 0, n,   0,  63)); break;
        case 6: colour = rainbowColor(map(b, 0, n,   0, 159)); break;
      tft.fillRect(x + b*(w+g), y, w, h, colour);
      tft.fillRect(x + b*(w+g), y, w, h, TFT_DARKGREY);
String printHex(byte *buffer, byte bufferSize) {
  String id = "";
  for (byte i = 0; i < bufferSize; i++) {
    id += buffer[i] < 0x10 ? "0" : "";
    id += String(buffer[i], HEX);
  return id;
Ja ... und wie sieht das Problem konkret aus? Sollen wir das etwa herausfinden? Isses zu schnell/langsam/bunt/grell/warm/regnerisch oder vielleicht olfaktorsch nicht so der Hit?
Gruß
Gregor
Wenn ich das richtig verstanden habe, wird der Animationscode genau einmal ausgeführt. Entweder steht die Abschaltbedingung an der falschen Stelle oder es fehlt schlicht eine richtige.
if (isProgress)
    reading++;
    if (reading > 22)
      reading = 0;
  isProgress = false;  // <--- hier wird nach einem Durchlauf abgeschaltet
Konkret wird eine sekunde abgespielt statt 5 sekunden. interval ist auf 5000 gesetzt jedoch hat es keine wirkung.
Genau, aber nicht nach 1 sek. sondern nach 5 sek. soll die anim gestoppt werden.
