RCSWITCH lack of documentation
I am using RCSWITCH to send a 64 bit number and for some reason if I set "setRepeatTransmit" a number smaller than 16 nothing is transmited, if I set it to a higher value than 16 the data will be transmitted more than one time.
The same happens when I try to send a 32 bit but I need to set "setRepeatTransmit" to 8 otherwise the same happens above.
I cant find any documentatioin of what is the "setRepeatTransmit" doing. Any person here have ever asked that yourself?
[sarcasm]The problem is on line 28 of the program you have not posted[/sarcasm]
Read this before posting a programming question
Sigh...
Does your code really have a smiley in it ?
Did you Read this before posting a programming question ?
You have the source code for the library. If you cannot figure out what it is doing please post it here, but make sure that it does not have any smileys in it.
Can you see the smiley in the code in reply #2 ? Why do you think it is there ? Do you see it in the code in the IDE on your PC ?
