Hello everyone,
I a currently building a remote control for a sunscreen: Funk & WLAN Markisensteuerung mit ESP8266 und Arduino - Bastel & Reparatur Blog
Really neat project however I fail using more than one remote control for the same funtion. Each of the works on its own but not together.
Can anyone point me in the right direction ?? Every help is well appreciated.
Cheers,
Dirk
This is the sourcecode:
// Markisensteuerung
// mit Arduino und ESP8266 (mit Arduino IDE Integration)
// Teil 1: Arduino Code
// Stefan Thesen 05/2015
// Free for anybody - no warranties
// use this as debug pin - the LED is on, if Motor1 is set down
#define LEDPIN 13
// Receive-Buffer - for Softserial / WIFI reading
#define RECV_BUFFER_SIZE 20
char RECV_Buffer[RECV_BUFFER_SIZE];
// assign serial ports
#define WIFI_Serial mySerial
#define Debug_Serial Serial
#include <SoftwareSerial.h>
SoftwareSerial mySerial(3,4); // RX, TX
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
unsigned long lRFOldValue=0; // to check for consecutive reads on 433MHz
int iRFCodeRepeat=0; // how many repeated codes receiver of 433MHz?
// Number of Motors to control
#define NO_MOTOR 2
// at which pin is motor 0's 1st pin? - A0 is pin 14, A1=15 ...
#define MOTOR_PIN_OFFSET 14
// ESP8266 reset pin
#define ESP_RESET 5
// array for the fc receive codes
unsigned long RFCode[NO_MOTOR][2];
// state of the motors
int iMotorState[NO_MOTOR];
#define MOTOR_UP -1
#define MOTOR_STOP 0
#define MOTOR_DOWN 1
#define MOTOR_INVAL -999
// time to wait when turning motor off or changing direction
// recommended to allow motor capacitor to unload over motor coil
#define MOTOR_WAIT_MS 300
// time for direction relay to swtich before power is applied
// recommended to avoid implicit switch of direction with power on
#define RELAIS_WAIT_MS 150
// duration of a motor event
#define EVENT_MS 120000
#define DEBOUNCE_MS 1000
unsigned long ulMotorEventEnd[NO_MOTOR]; // end of current motor event
unsigned long ulRFEventDeBounce; // timer for RF event on 433MHz (needed for debouncing)
// sets a motor into up/down/stop state
void SetMotor(int iMotor, int iState)
// calculate output pins
int iMotorPwr=2*iMotor +MOTOR_PIN_OFFSET;
int iMotorDir=2*iMotor+1 +MOTOR_PIN_OFFSET;
// define output state
pinMode(iMotorPwr,OUTPUT);
pinMode(iMotorDir,OUTPUT);
// pin n is motor power; pin n+1 is motor direction for motor 0; etc...
// relais board INVERTS!!! - HIGH = OFF
if (iState==MOTOR_STOP)
digitalWrite(iMotorPwr,HIGH);
delay(MOTOR_WAIT_MS); // wait some time to allow motor capacitor to unload over motor coil
digitalWrite(iMotorDir,HIGH);
ulMotorEventEnd[iMotor]=millis();
Debug_Serial.print("Motor STOP:");
Debug_Serial.println(iMotor);
else if (iState==MOTOR_UP)
// if still driving, stop first (incl delay)
if (iMotorState[iMotor]!=MOTOR_STOP) {SetMotor(iMotor,MOTOR_STOP);}
delay(RELAIS_WAIT_MS);
digitalWrite(iMotorPwr,LOW);
ulMotorEventEnd[iMotor]=millis()+EVENT_MS;
Debug_Serial.print("Motor UP:");
else if (iState==MOTOR_DOWN)
digitalWrite(iMotorDir,LOW);
Debug_Serial.print("Motor DOWN:");
// debug output: motor 0 to LED pin
if(iMotor==0)
if (iState==MOTOR_DOWN) {digitalWrite(LEDPIN,HIGH);}
else {digitalWrite(LEDPIN,LOW);}
// remember state
iMotorState[iMotor]=iState;
// setup routine
// init serials - make sure ESP8266 on WIFI_Serial is also at 9600
Debug_Serial.begin(9600);
WIFI_Serial.begin(9600);
// set-up rf receiver
mySwitch.enableReceive(0); // 433MHz Receiver on interrupt 0 => that is pin #2
ulRFEventDeBounce=0;
Debug_Serial.println("Markisensteuerung - S.Thesen 5/2015");
// define RF receiver codes - place your codes here, if you want 433MHz support
RFCode[0][0]=123456701;12345678; // left switch off
RFCode[1][0]=123456702; // right switch off I'd rather have this remote control the first motor aswell
RFCode[0][1]=123456703; // left switch on
RFCode[1][1]=123456704; // right switch on I'd rather have this remote control the first motor aswell
// set-up motor states
for (int ii=0;ii<NO_MOTOR;ii++)
SetMotor(ii,MOTOR_STOP);
// set-up output
pinMode(LEDPIN, OUTPUT);
digitalWrite(LEDPIN, LOW);
// reset ESP8266
pinMode(ESP_RESET, OUTPUT);
digitalWrite(ESP_RESET, LOW);
digitalWrite(ESP_RESET, HIGH);
// main loop
// handle WIFI
if(WIFI_Serial.available())
if (WIFI_Serial.findUntil("MOTOR", "\n"))
if (WIFI_Serial.readBytesUntil('\n', RECV_Buffer, RECV_BUFFER_SIZE))
// we should now have the motor number in ascii in receive buffer
int iMotor = RECV_Buffer[0] -48 -1; // -1 as webinterface calls Motor0 MOTOR1
int iCommand=MOTOR_INVAL;
if (iMotor>=0 && iMotor<=9)
Debug_Serial.print("Motor ");
Debug_Serial.print(iMotor);
if (strncmp(&RECV_Buffer[1], "UP", 2) == 0)
iCommand=MOTOR_UP;
else if (strncmp(&RECV_Buffer[1], "DOWN", 4) == 0)
iCommand=MOTOR_DOWN;
else if (strncmp(&RECV_Buffer[1], "STOP", 4) == 0)
iCommand=MOTOR_STOP;
Debug_Serial.print(" Kommando ");
Debug_Serial.println(iCommand);
if (iCommand!=MOTOR_INVAL)
// drive motor
SetMotor(iMotor,iCommand);
// reset RF code repeat (we might want to stop via RF what WIFI did)
iRFCodeRepeat=0;
lRFOldValue=0;
// handle 433MHz
if (mySwitch.available())
unsigned long value = mySwitch.getReceivedValue();
if (value == 0)
Debug_Serial.print("Unknown encoding");
Debug_Serial.print("Received ");
Debug_Serial.print( value );
Debug_Serial.print(" / ");
Debug_Serial.print( mySwitch.getReceivedBitlength() );
Debug_Serial.print("bit ");
Debug_Serial.print("Protocol: ");
Debug_Serial.println( mySwitch.getReceivedProtocol() );
// find code in list
for (int ij=0;ij<2;ij++)
if (value == RFCode[ii][ij])
if (value == lRFOldValue)
iRFCodeRepeat++;
else // use only new commands
iRFCodeRepeat=0;
ulRFEventDeBounce=millis()+DEBOUNCE_MS;
Debug_Serial.print("Using RF Command:");
Debug_Serial.print(ii);
Debug_Serial.print(",");
Debug_Serial.println(ij);
// drive motor
// motor already running? - then stop
if (iMotorState[ii]!=MOTOR_STOP)
else if (ij==0) { SetMotor(ii,MOTOR_UP); }
else if (ij==1) { SetMotor(ii,MOTOR_DOWN); }
// store current command as old now
lRFOldValue = value;
mySwitch.resetAvailable();
// debounce 433MHz RF input
if (ulRFEventDeBounce<millis())
iRFCodeRepeat=0;
lRFOldValue=0;
// check for end timestamp of motor events
if (ulMotorEventEnd[ii]<millis())
// stop motor if required
iRFCodeRepeat=0;
lRFOldValue=0;
