bonjour , j ai un arduino uno avec un shield ethernet je control des relais via internet grace a a domoticz installer sur un raspberry . voici le code
//ARDUINO 1.0+ ONLY
//ARDUINO 1.0+ ONLY
#include <Ethernet.h>
#include <SPI.h>
#include <RCSwitch.h> //ajout
boolean reading = false;
//CONFIGURE
byte ip[] = { 192, 168, 1, 10 }; //Manual setup only
byte gateway[] = { 192, 168, 1, 1 }; //Manual setup only
byte subnet[] = { 255, 255, 255, 0 }; //Manual setup only
// if need to change the MAC address (Very Rare)
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
EthernetServer server = EthernetServer(80); //port 80
RCSwitch mySwitch = RCSwitch(); //ajout
void setup(){
mySwitch.enableReceive(0); // Receiver on inerrupt 0 => that is pin #2 //ajout
//Pins 10,11,12 & 13 are used by the ethernet shield
//pinMode(2, OUTPUT);
//pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
//pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
//pinMode(7, OUTPUT);
//pinMode(8, OUTPUT);
//pinMode(9, OUTPUT);
Ethernet.begin(mac);
//Ethernet.begin(mac, ip, gateway, subnet); //for manual setup
server.begin();
Serial.println(Ethernet.localIP());
void loop(){
/* if (mySwitch.available()) { //ajout
int value = mySwitch.getReceivedValue();
if (value == 0) {
Serial.print("Unknown encoding");
Serial.print("Received ");
Serial.print( mySwitch.getReceivedValue() );
Serial.print(" / ");
Serial.print( mySwitch.getReceivedBitlength() );
Serial.print("bit ");
Serial.print("Protocol: ");
Serial.println( mySwitch.getReceivedProtocol() );
mySwitch.resetAvailable();
// listen for incoming clients, and process qequest.
checkForClient();
void checkForClient(){
if (client) {
// an http request ends with a blank line
boolean currentLineIsBlank = true;
boolean sentHeader = false;
while (client.connected()) {
if (client.available()) {
if(!sentHeader){
// send a standard http response header
client.println("Content-Type: text/html");
client.println();
sentHeader = true;
char c = client.read();
if(reading && c == ' ') reading = false;
if(c == '?') reading = true; //found the ?, begin reading the info
if(reading){
Serial.print(c);
switch (c) {
case '2':
//add code here to trigger on 2
triggerPin(2, client);
case '3':
//add code here to trigger on 3
triggerPin(3, client);
case '4':
//add code here to trigger on 4
triggerPin(4, client);
case '5':
//add code here to trigger on 5
triggerPin(5, client);
case '6':
//add code here to trigger on 6
triggerPin(6, client);
case '7':
//add code here to trigger on 7
triggerPin(7, client);
case '8':
//add code here to trigger on 8
triggerPin(8, client);
case '9':
//add code here to trigger on 9
triggerPin(9, client);
if (c == '\n' && currentLineIsBlank) break;
if (c == '\n') {
}else if (c != '\r') {
currentLineIsBlank = false;
delay(1); // give the web browser time to receive the data
client.stop(); // close the connection:
void triggerPin(int pin, EthernetClient client){
//blink a pin - Client needed just for HTML output purposes.
client.print("Turning on pin ");
client.println(pin);
client.print("
digitalWrite(pin, HIGH);
delay(25);
digitalWrite(pin, LOW);
delay(25);
dedans j ai introduit un code rcswitch car j aimerai sniffer les codes 433 et les envoyer sur le port serie du raspberry
est ce que c est possible? si oui je dois le mettre ou ?
le code rcswitch
Simple example for receiving
http://code.google.com/p/rc-switch/
if (value == 0) {
