Rduino DUE R3-E connection to NRF24L01 moudle has never been able to work properly?
I have tried many methods including asking the chatGPT but cannot solve this problem.the result s show that the nRF24L01 module not connected and nRF24L01 initialize failed.
I am looking forward to getting your answer. Thanks.
[pinout]
|nRF24L01 Arduino Due (ICSP )|
|VCC |3.3V|
|GND |GND|
|CE |D9|
|CSN |D10|
|SCK|
ICSP Pin 3 (SCK)|
|MOSI|
ICSP Pin 4 (MOSI)|
|MISO|
ICSP Pin 1 (MISO)**|
Welcome and good luck! You have given a list but it is useless for problem solving. You need to post an annotated schematic showing exactly what you have, be sure to show all connections, power, ground, power sources and any other external hardware items. It is also possible it is your software so you need to post that as well.
I think I know what the problem is but at this point I cannot be reasonably accurate.
try DUE receiver
//  Arduino DUE > NRF24L01 receiver test using a text string
// NOTE - NRF24L10 VCC to 3.3V and GND to GND
// UNO/Nano connections
// arduino SCK pin 11 goes to NRF24L10_pin MOSI
// arduino MISO pin 12 goes to NRF24L10_pin MI
// arduino MOSI pin 13 goes to NRF24L10_pin SCK
// NRF24L10 CE to arduino pin 9
// NRF24L10 CSN to arduino pin10
// ESP32 connections
// ESP32 SCK pin GPIO18 goes to NRF24L10_pin SCK
// ESP32 MISO pin GPIO19 goes to NRF24L10_pin MI
// ESP32 MOSI pin GPIO23 goes to NRF24L10_pin MO
// NRF24L10 CE to ESP32 pin GPIO4
// NRF24L10 CSN to ESP32 pin GPIO 5
// Arduino DUE connections
// DUE ICSP SCK pin  goes to NRF24L10_pin SCK
// DUE ICSP MISO pin  goes to NRF24L10_pin MI
// DUE ICSP MOSI pin  goes to NRF24L10_pin MO
// NRF24L10 CE to DUE pin GPIO9
// NRF24L10 CSN to DUE pin GPIO10
#include <SPI.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
bool radioNumber = 1;
const uint8_t pipes[][6] = { "1Node", "2Node" };
RF24 radio(CE_PIN, CSN_PIN);
char dataReceived[10];  // this must match dataToSend in the TX
bool newData = false;
  Serial.println("Arduino DUE > NRF24L01 Receive text");
  radio.begin();
  if (radio.isChipConnected())
    Serial.println("Receiver NF24 connected to SPI");
  else {
    Serial.println("NF24 is NOT connected to SPI");
    while (1)
  radio.setChannel(125);
  radio.setDataRate(RF24_1MBPS);
  //radio.setDataRate(RF24_250KBPS);
  radio.printDetails();
  if (!radioNumber) {
    radio.openWritingPipe(pipes[0]);
    radio.openReadingPipe(1, pipes[1]);
    radio.openWritingPipe(pipes[1]);
    radio.openReadingPipe(1, pipes[0]);
  radio.startListening();
  // radio.setPayloadSize(sizeof(Struct1));
  if (radio.available()) {
    char testString[10] = "";
    radio.read(testString, sizeof(testString));
    Serial.print("Test string:      ");
    Serial.println(testString);
Nano transmitter
// Nano > NRF24L01 transmitter test using a text string
// RP2040 connections
// RP2040 SPIO_SCK pin GP18 goes to NRF24L10_pin SCK
// RP2040 SPIO_RX pin GP16 goes to NRF24L10_pin MISO
// RP2040 SPIO_TX pin GP19 goes to NRF24L10_pin MOSI
// RP2040 pin SPIO_CSn GP17 to NRF24L10 CSN
// RP2040 pin GP20 to NRF24L10 CE
// RP2040 GND and 3.3V to NRF24L10  GND and VCC
// Leonardo connections ???
// Leonardo ICSP SCK  pin 15 to NRF24L10_pin SCK
// Leonardo ICSP MISO pin 14 to NRF24L10_pin MISO
// Leonardo ICSP MOSI pin 16 to NRF24L10_pin MOSI
// Leonardo pin 10 to NRF24L10 CSN
// Leonardo pin 9  to NRF24L10 CE
// Leonardo GND and 3.3V to NRF24L10  GND and VCC
// ESP8266 connections
// ESP8266 SCK pin GPIO14 goes to NRF24L10_pin SCK
// ESP8266 MISO pin GPIO12 goes to NRF24L10_pin MI
// ESP8266 MOSI pin GPIO13 goes to NRF24L10_pin MO
// NRF24L10 CE to ESP8266 pin GPIO4
// NRF24L10 CSN to ESP8266 pin GPIO5
// arduino MOSI pin 11 goes to NRF24L10_pin MOSI
// arduino SCK  pin 13 goes to NRF24L10_pin SCK
// NRF24L10 VCC to 3.3V and GND to GND
#include <SPI.h>
#include "RF24.h"
#define CE_PIN 9
#define CSN_PIN 10
bool radioNumber = 0;
byte addresses[][6] = { "1Node", "2Node" };
  delay(2000);
  Serial.println("\n\nNano > NRF24L01 transmit text");
  radio.begin();
    Serial.println("Transmitter NF24 connected to SPI");
  else {
    while (1)
  radio.setPALevel(RF24_PA_MIN);
  radio.powerUp();
  if (radioNumber) {
    radio.openWritingPipe(addresses[1]);
    radio.openReadingPipe(1, addresses[0]);
    radio.openWritingPipe(addresses[0]);
    radio.openReadingPipe(1, addresses[1]);
  radio.stopListening();
  //radio.setPayloadSize(sizeof(Struct1));
// loop transmiting data packet
  static char testString[10] = "text 0";
  radio.write(testString, sizeof(testString));
  Serial.print("transmit ");
  testString[5]++;
nano transmitter output
transmit text 0
transmit text 1
transmit text 2
transmit text 3
transmit text 4
transmit text 5
transmit text 6
transmit text 7
DUE receiver output
= 10 Mhz
STATUS		= 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
RX_ADDR_P0-1	= 0xe7e7e7e7e7 0xc2c2c2c2c2
RX_ADDR_P2-5	= 0xc3 0xc4 0xc5 0xc6
TX_ADDR		= 0xe7e7e7e7e7
RX_PW_P0-6	= 0x20 0x20 0x20 0x20 0x20 0x20
EN_AA		= 0x3f
EN_RXADDR	= 0x03
RF_CH		= 0x7d
RF_SETUP	= 0x07
CONFIG		= 0x0e
DYNPD/FEATURE	= 0x00 0x00
Data Rate	= 1 MBPS
Model		= nRF24L01+
CRC Length	= 16 bits
PA Power	= PA_MAX
ARC		= 0
Test string:      text p
Test string:      text q
Test string:      text r
Test string:      text s
Test string:      text t
Test string:      text u
Test string:      text v
Test string:      text w
Test string:      text x
Test string:      text y
Test string:      text z
Test string:      text {
Test string:      text |
I think I see your problem:
Power Stability Issues with RF24 Radio Modules
As described in the RF24 Common Issues Guide, radio modules, especially the PA+LNA versions, are highly reliant on a stable power source. The 3.3V output from Arduino is not stable enough for these modules in many applications. While they may work with an inadequate power supply, you may experience lost packets or reduced reception compared to modules powered by a more stable source. Better luck will be obtained using an external power supply.
Symptoms of Power Issues:
  • Radio module performance may improve when touched, indicating power stability issues.
  • These issues are often caused by the absence of a capacitor, a common cost-saving omission by some manufacturers.
Temporary Patch :
  • Add Capacitors: Place capacitors close to the VCC and GND pins of the radio module. A 10uF capacitor is usually sufficient, but the exact value can depend on your circuit layout.
  • Use Low ESR Capacitors: Capacitors with low Equivalent Series Resistance (ESR) are recommended, as they provide better power stability and performance.
Adding the appropriate capacitors can greatly improve the reliability of your RF24 module by ensuring a stable power supply, thus minimizing packet loss and enhancing overall performance. A separate power supply for the radios is the best solution.
Gil's Crispy Critter Rules for Processor Hardware:
  1. Rule #1: An Arduino is NOT a Power Supply!
  2. Rule #2: Never connect anything inductive (motors, speakers) directly to an Arduino!
  3. Rule #3: Avoid connecting or disconnecting wires while the power is on.
  4. Rule #4: Do not apply power to any pin unless you are certain of what you're doing.
  5. Rule #5: Do not exceed the maximum voltage ratings.
  6. Rule #6: Many Arduinos cannot power transmitters directly.
  7. Rule #7: Before powering your project, take a break and double-check the wiring.
LaryD’s Corollaries:
  1. Coro #1: When starting out, add a 220Ω resistor in series with both input and output pins to protect against shorts.
  2. Coro #2: Invest in a Digital Multi-Meter (DMM) to measure voltages, currents, and resistance.
Note: Violating these rules can turn your Arduinos into crispy critters. For optimal performance, keep your wires under 25 cm (10 inches).
Additional Tips:
  • The L293 motor driver, though common, is inefficient as it can lose around 3V as heat when driving both legs of a motor. Consider using a motor driver with MOSFET outputs to reduce heat loss and conserve battery power.
  • For more on powering Arduino boards, explore this guide: Powering Alternatives for Arduino Boards.
