Re-assign pot value to Serial.print
Thank you in advance for any help, direction or guidance.
Im playing arouund with the function:
outputValue = map(sensorValue, 0, 1023, 0, 255);
I have a continous potentiometer wind vane from 0 to 1023. Instead of 1023 increments, I need 360 deg. increments.
Is there a simple way to re-assign values so i can print to serial monitor.
Im using this sketch as template to play around with.
-Ken
OutputValue = map(sensorValue, 0,1023,0,360) doesn't do what you want? OutputValue needs to be a 16 bit int.
