were you able to make it work? after uploading your code it just counts till 9, and it dosen't shiftout to next digit rather both digits show same numbers
Moderator edit: split from Button Code - Project Guidance - Arduino Forum
ok, let’s get back to basics...
we have your code, now post a complete wiring diagram (schematic) of how all your parts are connected together.
Not fritzing, a real pen on paper, or cad drawing that shows all the connections and parts.
It’s already been said this is a hardware problem, so we need to see how you’ve plonked the bits together. You can keep burning boards as long as you want, but to help, we need to see what’s happening.
This thread started about a year ago. I suspect th OP has moved on by now and the thread has been high jacked.
oops - thanks!
lastchancename:
we have your code, now post a complete wiring diagram (schematic) of how all your parts are connected together.Not fritzing, a real pen on paper, or cad drawing that shows all the connections and parts.
I have attached schematics and code, thanks!
//GPIO declarations
byte segmentClock = 3;
byte segmentLatch = 4;
byte segmentData = 2;
int upButton = 8;
int downButton = 9;
int score = 0;
Serial.println("Large Digit Driver Example");
pinMode(segmentClock, OUTPUT);
pinMode(segmentData, OUTPUT);
pinMode(segmentLatch, OUTPUT);
pinMode(upButton, INPUT_PULLUP);
pinMode(downButton, INPUT_PULLUP);
digitalWrite(segmentClock, LOW);
digitalWrite(segmentData, LOW);
digitalWrite(segmentLatch, LOW);
int number = 0;
postNumber(score,false); //show decimal
digitalWrite(segmentLatch, HIGH);
if (! digitalRead(upButton)) {
score++;
score %=10;
Serial.println(score); //For debugging
delay (300);
if (! digitalRead(downButton)) {
score--;
if(score < 0) score +9;
delay (300);
//Takes a number and displays 2 numbers. Displays absolute value (no negatives)
void showNumber(float value)
int number = abs(value); //Remove negative signs and any decimals
//Serial.print("number: ");
//Serial.println(number);
for (byte x = 0 ; x < 2 ; x++)
int remainder = number % 10;
postNumber(remainder, false);
number /= 10;
//Latch the current segment data
digitalWrite(segmentLatch, HIGH); //Register moves storage register on the rising edge of RCK
//Given a number, or '-', shifts it out to the display
void postNumber(byte number, boolean decimal)
// - A
// / / F/B
// - G
// / / E/C
// -. D/DP
#define a 1<<0
#define b 1<<6
#define c 1<<5
#define d 1<<4
#define e 1<<3
#define f 1<<1
#define g 1<<2
#define dp 1<<7
byte segments;
switch (number)
case 1: segments = b | c; break;
case 2: segments = a | b | d | e | g; break;
case 3: segments = a | b | c | d | g; break;
case 4: segments = f | g | b | c; break;
case 5: segments = a | f | g | c | d; break;
case 6: segments = a | f | g | e | c | d; break;
case 7: segments = a | b | c; break;
case 8: segments = a | b | c | d | e | f | g; break;
case 9: segments = a | b | c | d | f | g; break;
case 0: segments = a | b | c | d | e | f; break;
case ' ': segments = 0; break;
case 'c': segments = g | e | d; break;
case '-': segments = g; break;
if (decimal) segments |= dp;
//Clock these bits out to the drivers
for (byte x = 0 ; x < 8 ; x++)
digitalWrite(segmentData, segments & 1 << (7 - x));
digitalWrite(segmentClock, HIGH); //Data transfers to the register on the rising edge of SRCK
COUNTER_UP_DOWN.ino (3.66 KB)
Welcome to the forum.
You will be better to start a new thread.
Tom...
@donknowz, do not hijack. Thread split.
