Re: Glade library
Glade
Glade is a free software 8-bit audio library for use with Arduino.
Do somebody manage to use Glade audio library ?
I'd like to make it work, but it seems to be a work-in-process.
Glade wiki -> Google Code Archive - Long-term storage for Google Code Project Hosting.
Audio library -> http://glade.googlecode.com/svn/!svn/bc/30/trunk/trunk/Audio
Glade library -> http://glade.googlecode.com/svn-history/r30/trunk/trunk/Glade
ERROR i get wen Arduino compile automaticaly the library :
Glade.cpp: In member function 'void GladeEngine::run(long int)':
Glade.cpp:118: warning: comparison between signed and unsigned integer expressions
Glade.h: At global scope:
Glade.h:62: warning: alignment of 'GladeNode::_ZTV9GladeNode' is greater than maximum object file alignment.  Using 1
Glade.h:80: warning: alignment of 'GladeOutput::_ZTV11GladeOutput' is greater than maximum object file alignment.  Using 1
GladeAdd.h:26: warning: alignment of 'GladeAdd::_ZTV8GladeAdd' is greater than maximum object file alignment.  Using 1
GladeBlend.h:26: warning: alignment of 'GladeBlend::_ZTV10GladeBlend' is greater than maximum object file alignment.  Using 1
GladeClip.h:26: warning: alignment of 'GladeClip::_ZTV9GladeClip' is greater than maximum object file alignment.  Using 1
/Applications/arduino-0011/hardware/tools/avr/bin/../lib/gcc/avr/4.0.2/../../../../avr/include/stdlib.h:78: error: expected unqualified-id before 'int'
/Applications/arduino-0011/hardware/tools/avr/bin/../lib/gcc/avr/4.0.2/../../../../avr/include/stdlib.h:78: error: expected `)' before 'int'
/Applications/arduino-0011/hardware/tools/avr/bin/../lib/gcc/avr/4.0.2/../../../../avr/include/stdlib.h:114: error: expected unqualified-id before 'int'
/Applications/arduino-0011/hardware/tools/avr/bin/../lib/gcc/avr/4.0.2/../../../../avr/include/stdlib.h:114: error: expected `)' before 'int'
/Applications/arduino-0011/hardware/tools/avr/bin/../lib/gcc/avr/4.0.2/../../../../avr/include/stdlib.h:147: error: expected identifier before '(' token
/Applications/arduino-0011/hardware/tools/avr/bin/../lib/gcc/avr/4.0.2/../../../../avr/include/stdlib.h:147: error: expected `)' before '(' token
/Applications/arduino-0011/hardware/tools/avr/bin/../lib/gcc/avr/4.0.2/../../../../avr/include/stdlib.h:147: error: expected ',' or '...' before '(' token
/Applications/arduino-0011/hardware/tools/avr/bin/../lib/gcc/avr/4.0.2/../../../../avr/include/stdlib.h:147: error: expected initializer before ')' token
/Applications/arduino-0011/hardware/tools/avr/bin/../lib/gcc/avr/4.0.2/../../../../avr/include/stdlib.h:179: error: '__compar_fn_t' has not been declared
GladeDelay.h:26: warning: alignment of 'GladeDelay::_ZTV10GladeDelay' is greater than maximum object file alignment.  Using 1
