i would want measure the GPS coordinates of the board with a GPS module and transmit them, after the request through an sms, using a GSM module please give me good my gps is neo 6
is gps neo 6 is compatible with sim 800?
software serial is quite troubling in using with GPS. try this library NeoGPS it helps you solve the trouble with floats. Also check the other GPS projects here it will give you insights.
cheers,
sen
