Re: Help me turn on led by SMS
Hello there
I follow all the instructions to open an LED on this site http://www.instructables.com/id/Control-the-relays-via-GPRS-SMS/?ALLSTEPS
but when i send sms nothing happend.
Any ideas please??
Code?
Did you do some debug using serial Port?
Same happened to me nothing, same SIM900 but not working! Famously String mostly not working, other code use char inchar; character each its fine.
FallenRider:
Hello there
Any ideas please??
I solved, not that code, other code, need add #include SIM900.h use libraries GSMSHIELD, all works fine, perfectly, if your GSM Shield use rest 2 and 3 pins are software, found code like this; but that rgb led, you can edit code yourself, I did. Good luck, Cheers.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs
#include "SIM900.h"
#include "sms.h"
#include "SoftwareSerial.h"
#include "sms.h"
SMSGSM sms;
int red = 10;    // RED LED connected to PWM pin 3
int green = 11;    // GREEN LED connected to PWM pin 5
int blue = 6;    // BLUE LED connected to PWM pin 6
int r=50; int g=100; int b=150;
int rup; int gup; int bup;
boolean started=false;
char smsbuffer[160];
char n[20];
int fader=1;
int inc=10;
  //Serial connection.
  Serial.println("GSM Shield testing.");
  //Start configuration of shield with baudrate.
  if (gsm.begin(2400)){
    Serial.println("\nstatus=READY");
    started=true;
  else Serial.println("\nstatus=IDLE");
  if(started){
    delsms();
  int pos=0;
  //Serial.println("Loop");
  if(started){
    pos=sms.IsSMSPresent(SMS_ALL);
    if(pos){
      Serial.println("IsSMSPresent at pos ");
      Serial.println(pos);
      sms.GetSMS(pos,n,smsbuffer,100);
        Serial.println(n);
        Serial.println(smsbuffer);
        if(!strcmp(smsbuffer,"R")){
          Serial.println("RED");
          r=255;
          g=0;
          b=0;
        if(!strcmp(smsbuffer,"G")){
          Serial.println("GREEN");
          r=0;
          g=255;
          b=0;
        if(!strcmp(smsbuffer,"B")){
          Serial.println("BLUE");
          r=0;
          g=0;
          b=255;
        if(!strcmp(smsbuffer,"P")){
          Serial.println("PURPLE");
          r=255;
          g=0;
          b=255;
        if(!strcmp(smsbuffer,"Y")){
          Serial.println("YELLOW");
          r=255;
          g=255;
          b=0;
        if(!strcmp(smsbuffer,"O")){
          Serial.println("ORANGE");
          r=255;
          g=165;
          b=0;
        if(!strcmp(smsbuffer,"W")){
          Serial.println("WHITE");
          r=255;
          g=255;
          b=255;
        if(!strcmp(smsbuffer,"F")){
          Serial.println("FADER");
          fader=1;
          r=50; g=100; b=150;
          fader=0;
        rgb(r, g, b);
        delsms();
    if(fader){
      funcfader();
void delsms(){
  Serial.println("delsms");
  for (int i=0; i<10; i++){  //do it max 10 times
      int pos=sms.IsSMSPresent(SMS_ALL);
      if (pos!=0){
        Serial.print("\nFind SMS at the pos ");
        if (sms.DeleteSMS(pos)==1){
          Serial.print("\nDeleted SMS at the pos ");
          Serial.print("\nCant del SMS at the pos ");
void funcfader(){
    if (rup==1){r+=1;}
    else{r-=1;}
    if (r>=255){rup=0;}
    if (r<=0){rup=1;}
    if (gup==1){g+=1;}
    else{g-=1;}
    if (g>=255){gup=0;}
    if (g<=0){gup=1;}
    if (bup==1){b+=1;}
    else{b-=1;}
    if (b>=255){bup=0;}
    if (b<=0){bup=1;}
    rgb(r, g, b);
void rgb(int r, int g, int b)
 if (r>255) r=255;
  if (g>255) g=255;
  if (b>255) b=255;
  if (r<0) r=0;
  if (g<0) g=0;
  if (b<0) b=0;
  analogWrite(red, r);
  analogWrite(green, g);
  analogWrite(blue, b);
