hi all friends..
i still new in arduino ..my first project is to detect object using IR sensor..
if sensor detect object LED with be light and if object clear in < 5 sec nothing happen..but if sensor detect object and not clear in 5 sec relay will be on. i use 2 sensor for this project, my sketch function not properly relay still on although object already clear less that 5 sec. can any one help me?
this my sketch:
int sensa = 2; //Obstacle Sensor A
int sensb = 3; //Obstacle Sensor B
int led = 13; //Obstacle Sensor B
int relay = 4; // relay 5v
int sensora;
int sensorb;
// the setup routine runs once when you press reset:
//Everything written here will run only once
//Initializing pins as inputs and outputs
pinMode(led, OUTPUT);
pinMode(sensa,INPUT);
pinMode(sensb,INPUT);
pinMode(relay,OUTPUT);
// The loop routine runs over and over again forever:
sensora = digitalRead(sensa);
if(sensora==LOW) //If obstacle is detected carrier
digitalWrite(led,HIGH); // LED ON
delay(5000);
digitalWrite(relay,HIGH);
delay(5000);
digitalWrite(led,LOW); // LED OFF
digitalWrite(relay,LOW);
sensorb = digitalRead(sensb);
if(sensorb==LOW)
delay(5000);
delay(5000);
In your program once your detector sees an obstacle the LED is turned on, then 5 seconds later the relay is turned on whether or not the obstacle is still in view and it stays on for another 5 seconds.
What you need to do is to check whether the obstruction is still there 5 seconds after the initial check and, if it is, turn on the relay.
yes my program now once sensor detected led on and 5 sec later relay on..
what i need is..once sensor detect object led ON but if object clear (or move ) less that 5 sec (sensor not detect ) relay not turn ON.
if object not clear in 5 sec ( or what timing we set ) relay turn ON.
i try edit this program to many time but still not work..pls help me
I gave you an idea in my previous post.
read the sensor
if an obstacle is detected
turn on the LED
start timing
wait five seconds
read the sensor again
turn on the relay
end if
turn of the LED
end else
end if
You need to check for an obstacle 5 seconds after the first check
You should also:
- Read the first two posts at the top of this forum
- Always reformat your code in the IDE before you post using Ctrl-T
- Post your sample code in between the code tags, using the '#' character just above your post, like
int sensora;
int sensorb;
delay(5000);
delay(5000);
if(sensorb==LOW)
delay(5000);
delay(5000);
yes..good idea
exactly i want function like this...
how to write code for this function?
You already have all the commands that you need in your existing code. There are better ways of waiting for 5 seconds than using delay() but for now just use delay().
ok..i get it..
all work fine..thanks for your support and help..
thanks you very much..
