Re: IDE 1.8.0 Released
Hez guys,
I want to build my own Arduino UNO, so I have started with this schematic and it works. My ATMEGA328p Chip is already bootloaded but I want to send some sketches with an USB TTL converter. I have this one:
I put RX to TX, TX to RX, 5V to 5v, GND to GND, DTR to the Reset of my Arduino. The CTS pin isn't connected.
My only problem is that I cannot send a sketch with the USB TTL Converter. I get some errors like this:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x96
Problème de téléversement vers la carte. Voir http://www.arduino.cc/en/Guide/Troubleshooting#upload pour suggestions.
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x96
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x96
What is your advice?
me he descargado el IDE comprimido al descomprimir me da error final inesperado del archivo. gracias, si me podeis ayudar . he intentado descargar otros ide y nada . windows 10 home.
Hello,
I have instaled 1.8.1 at brand new instalation of Windows Vista.
It is not possible to compile whaterer code. If I try to compile code, I got follow message:
Arduino: 1.8.1 (Windows Vista), "Arduino/Genuino Uno"
avr-g++: error: CreateProcess: No such file or directory
exit status 1
Could you help me to solte this issue?
Thanks. This version would awesome too.
:zd đèn uv
roffsolutions:
Even I am facing the same issue as discussed by OzOns
sayalikamat65:
I have the same problem as discussed by OzOns
I suspect you're both just spammers but if you're actually having the font issue and had taken the time to read the thread you would know the bug was fixed in Arduino IDE 1.8.1.
what this i dont know so hard for learn
hello
Well, Thanks for posting this guide. It will help others and me also.
HET ZAL WEL ZIJN EH
