Re: Led Matrix Processing, arduino control problems
Was there a question in there?
  if(true)
      Serial.print (0,BYTE);
      Serial.print (1,BYTE);
      Serial.print ((byte) Y1,BYTE);
      Serial.print (2,BYTE);
      Serial.print ((byte) Y2,BYTE);
      Serial.println (Y1);
      Serial.println (Y2);
Under what circumstances would the else block ever be executed?
Do you have you indent value set to random?
My question is, what im doing wrong in the arduino code. The processing at the moment ia not a big deal.
Im a mediumi-noob at the programming stuff :(
The forum is not a money making operation. As a result, our crystal ball was re-possessed.
You'll need to describe the symptoms, at the very least. Otherwise, we can just say that it must be your expectations that are wrong.
