Re: new project question/advice request
Hi I am brand new to arduino and have a specific project that I need to build. I need to build a basic device that will ring a buzzer once no matter how many times it is triggered in a set time. Its for a door alarm and I don't want it going off all the time. Has anyone already done a project like this?
Welcome to the forum.
benn1973, it may be better for you to start a new thread of your own, rather than joint into an established one.
Please read the first post in any forum entitled how to use this forum. http://forum.arduino.cc/index.php/topic,148850.0.html
Thanks.. Tom... :)
means, you want to have the buzzer ON all time, no matter if someone shut the door immediately after the alarm was initiated?
rpt007: Its for a door alarm and I don't want it going off all the time.
That's just a strange part of the English language, an alarm "goes off" when it actually goes on.
@aarg:
Let's see what the original PO tells us and what kind of English he will use then ;-)
aarg: That's just a strange part of the English language, an alarm "goes off" when it actually goes on.
Same as a bomb or gun going off.
...R
I am no native speaker and sometimes I fall into the trap that English language is not always logical. Lights go ON and OFF, you power your devices ON or OFF, but a buzzer goes OFF when it gets loud - just for my information: when you switch the power OFF of a buzzer, what is the right expression then - ON ?
rpt007: when you switch the power OFF of a buzzer, what is the right expression then - ON ?
It stops?
Please. We enjoy illogical English.
...R
monostable multivibrator
benn1973: Hi I am brand new to arduino and have a specific project that I need to build. I need to build a basic device that will ring a buzzer once no matter how many times it is triggered in a set time. Its for a door alarm and I don't want it going off all the time. Has anyone already done a project like this?
All you need to do is use millis() to manage the time between first reacting to a button press and the next reaction. Have a look at how the interval between button presses is done in Several Things at a Time. You just need a longer interval.
...R
dlloyd: monostable multivibrator
endoplasmic reticulum
look for 'non-retriggerable one-shot' circuit You can do that with a 555 or other single chip for about $1
If you are new here and have a arduino on your hands I would suggest you to run the basic examples using leds/resistors, buttons..etc while you pass the 5~10 examples you will have an idea how to do that and it's actually really simple.
D.60
lastchancename:
look for ‘non-retriggerable one-shot’ circuit
All such hardware circuits have a relatively short time to re-arm. If you want a really long time to pass before it can re-trigger, you have to use some other solution.
A hardware circuit (if suitable) may be a much cheaper way to implement something but in most cases using an Arduino will be much simpler. And definitely more versatile.
...R
