Re: Nextion 3.5 inch NX4832T035 float value
Hi dear all,
Can I write an xfloat number on the nextion instead of a text ? I designed a keypad buttons table and I can write a text but I don’t know how to write an xfloat . I need to send a generic value to arduino. Can somebody help me? thank you in advance. I am a beginner from Italy.
Please do not hijack. Thread split.
@trivalb - your duplicate topic, which was a hijack of an old topic, has been deleted
DO NOT hijack topics with your own question or cross post the same quetsion multiple times or you run the risk of a timeout from the forum
Cross-posting is against the rules of the forum. The reason is that duplicate posts can waste the time of the people trying to help. Someone might spend 15 minutes (or more) writing a detailed answer on this topic, without knowing that someone else already did the same in the other topic.
Repeated cross-posting will result in a timeout from the forum.
In the future, please take some time to pick the forum board that best suits the topic of your question and then only post once to that forum board. This is basic forum etiquette, as explained in the sticky “How to use this forum - please read.” post you will find at the top of every forum board. It contains a lot of other useful information. Please read it.
Thanks in advance for your cooperation.
Hello trivalb
Please can you read the tutorial Using Nextion displays with Arduino
If you want further help please read How to get the best out of this forum before posting anything else.
Thanks,
Hi ,
I'm a beginner on Arduino programming.
I'm looking for sending a generic float number to Arduino. I designed a page on the Nextion Editor and I can simulate it, but I need to convert t3 text to xfloat. Is it possible? Now I can write the number as t3 text pushing buttons. In each button I've written the command as shown in the picture
Take look at Nextion Instruction set , the covx command is what you are looking for.
Ciao, Ale.
