Edit: Double post
Is the Serial.begin(9600) different than the one in the serial monitor?
Nope, both are set to 9600.
Thanks for the response
Edit:
Even a simple
Serial.print("TEST");
comes out as an illegible string like above.
It definitely looks like a baud rate error.
Are you sure your oscillator frequency is 16 MHz?
Check out our new shield: http://www.ruggedcircuits.com/html/gadget_shield.html
No, I'm not really sure. :-?
I did play with the 9600 baud selection though, and found something.
If I change it to 4800 ( On the serial port window ) I get legible results.
Even though the code is listed at 9600. It seems to work in factors of two, if I change the code to 4800, I get legible results @ 2400 baud.
Then either you are using an 8 MHz oscillator or you have not programmed your fuses on the ATmega328 to make it use an external oscillator (16 MHz I'm assuming).
Well 16Mhz isn't perfect at 9600 anyway
http://www.wormfood.net/avrbaudcalc.php
Doesn't explain your issue though.
Presumably he got it pre-programmed and tested as an arduino pro mini but it might be that which is the issue.
Mowcius
Yes, I didn't do the programming myself. Though I am taking over the project, so I'm self teaching this stuff to myself
I think I found the issue, in the arduino setting I didn't have the correct board set... Once I correctly set the board to a Pro Mini, it works on 9600 baud.
Everything is working as intended at the moment, now I actually get to start coding it to do what we need
Ahh, glad the issue is sorted
