Re: Problem with servos
Hi every one,
I am absolutely going crazy trying to make this project to work.
I am using Audrino Nano. I have written code for 5 servos to move using five pins and a switch to drive the servos from 45 to 135 degrees, and back. I need to add a second switch that would make only 3 servos to move. Please help me!!!!!
Here's my code:
#include <Servo.h>
int pos = 45;
// Defining servos
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
Servo servo5;
void setup (){
pinMode(6, INPUT);
pinMode(7, INPUT);
//Servo pins in PWM
servo1.attach(2);
servo2.attach(3);
servo3.attach(4);
servo4.attach(5);
servo5.attach(6);
void loop(){
if (digitalRead(6) == HIGH && pos < 135) {
pos++;
servo1.write(pos);
servo2.write(pos);
servo3.write(pos);
servo4.write(pos);
servo5.write(pos);
delay(15);
if (digitalRead(7) == HIGH && pos > 45) {
pos--;
servo1.write(pos);
servo2.write(pos);
servo3.write(pos);
servo4.write(pos);
servo5.write(pos);
delay(15);
Do you have a common ground for all the servos, the power supply and the Arduino?
Please remember to use code tags when posting code.
Yes all servos have a common ground and they work fine. All I need is to see if some one can help me to to wrote a code that servos 3,4 and 5 would move from 45 to 135 degrees.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
Thanks.. Tom ... :slight_smile:
azflyer:
As stated that's really easy. Just take out the writes to servo1 and servo2.
But I guess you mean something else. You seem to have 2 switches already or at least you're using two pins. Do you plan to add a third? Or two more? Or if that is one switch where is the circuit diagram that shows how it is connected?
What exactly are the switch conditions that will make 3 servos instead of 5 servos go from 45-135 and what conditions make them go back from 135-45? And what is happening to the other 2 servos while they're doing it?
Steve
