Re: !!! Push Button Counter !!! EASY ANSWER PLEASE HELP
sir how i want to make parogramme for to push botton press 1 time give seven segmen display 1and by pressing 2 times give 2 on seven segment display
def11-22-33_44: sir how i want to make parogramme for to push botton press 1 time give seven segmen display 1and by pressing 2 times give 2 on seven segment display
You should start your own thread for your own question.
You should post the code you've tried so far and describe what happens when you run it and how that differs from what you want.
You should use code tags when you post that code.
def11-22-33_44:
Start by using GOOGLE.
You will find many examples, if you would just type …
GOOGLE => “arduino push button tutorial”
GOOGLE => “arduino 7 segment led tutorial”
https://www.youtube.com/watch?v=oL84Wo9PNYs
like this ?
I dont know why so many non english speakers start threads with a "sir".
They're trying to be polite? I don't have any issue with that.
Show us the work you have done so far. .
CrossRoads: They're trying to be polite? I don't have any issue with that.
I think the use of "sir" is seen differently in the USA. In Ireland (and Britain, I think) it conjures up the concept of master and servant which makes me uncomfortable. However there is no commonly used alternative.
...R
