Certainly. Just use the same algorithm. The default one on the Arduino is the Park-Miller "Minimal Standard".
If you need an implementation of that one or another one, let me know. I can either provide one or guide you to one.
Searching for the constants is a good way to pin down the default Arduino generator...
It is one of these. You can check the Arduino code for which one is used. They should be functionally identical. Scroll towards the bottom for the actual code.
This is a very fast one, the two initializers are the "seed"
// An example of a simple pseudo-random number generator is the
// Multiply-with-carry method invented by George Marsaglia.
// two initializers (not null)
unsigned long m_w = 1;
unsigned long m_z = 2;
unsigned long getRandom()
m_z = 36969L * (m_z & 65535L) + (m_z >> 16);
m_w = 18000L * (m_w & 65535L) + (m_w >> 16);
return (m_z << 16) + m_w; /* 32-bit result */
python version is like this
m_w = 1
m_z = 2
def getRandom():
global m_w
global m_z
m_z = (36969L * (m_z & 65535L) + (m_z >> 16)) & 0xFFFFFFFF
m_w = (18000L * (m_w & 65535L) + (m_w >> 16)) & 0xFFFFFFFF
return ((m_z << 16) + m_w) & 0xFFFFFFFF
for i in range(10):
print getRandom()
there might be a need to keep datatypes 32 bit (extra masking)
[yes -> added]
