I am currently doing a very similar task.
One way would be to copy the data from the serial monitor into notepad then read the text file into Matlab.
I am trying to use a timer interrupt to sample a digital sensor which is proving to be more work than I anticipated.
Here is my code I am using. I am experiencing problems with it freezing up the arduino IDE as soon as I open the serial monitor. So it doesn’t work, but this is the way I would go about sampling data. That is, taking in data at a known frequency which in this case is 8kHz.
//storage variables
volatile boolean toggle1 = 0;
void setup(){
//set pins
pinMode(13, INPUT);
cli();//stop interrupts
//set timer2 interrupt at 8kHz
TCCR2A = 0;// set entire TCCR2A register to 0
TCCR2B = 0;// same for TCCR2B
TCNT2 = 0;//initialize counter value to 0
// set compare match register for 8khz increments
OCR2A = 249;// = (16*10^6) / (8000*8) - 1 (must be <256)
// turn on CTC mode
TCCR2A |= (1 << WGM21);
// Set CS21 bit for 8 prescaler
TCCR2B |= (1 << CS21);
// enable timer compare interrupt
TIMSK2 |= (1 << OCIE2A);
sei();//allow interrupts
ISR(TIMER2_COMPA_vect){//reads digital pin
toggle1 = digitalRead(0);
void loop(){
//do other things here
Serial.write(toggle1);
Hello,
I am trying to sample a digital signal at a minimum of 8kHz and be able to communicate it to the computer. Does anyone have any code or suggestions for this? I am currently trying to use this code below but it locks up every time I run it. Any help would be appreciated.
//storage variables
volatile boolean state = 0;
void setup(){
//set pins as outputs
pinMode(13, INPUT);
// turn on CTC mode
}//end setup
ISR(TIMER2_COMPA_vect){//timer1 interrupt 8kHz reads pin 13.
state = digitalRead(0);
//Serial.write(state);
void loop(){
Whenever I run Serial communication with the computer the Arduino IDE freezes up.
Serial.write(state) sends binary values to the IDE, not the ascii characters '0' or '1'. Is this what you wanted?
The binary values may be locking up the IDE.
The interrupt routine samples the state of pin 0 at 8kHz.
The loop() function just writes (or prints) the value of state repeatedly without being synchronized with the interrupt. To do that you need to set a flag in the interrupt routine and then the loop function checks that flag before it prints the state.
Okay, I got a similar version of the code to work at 2kHz. Also moving the Serial.print to the loop seemed to fix the issue!
I will post my updated code incase anyone wants to use a basic 2kHz timer interrupt code.
//storage variables
volatile int state = 0; //input variable
void setup(){
pinMode(5, INPUT);
//set timer0 interrupt at 2kHz
TCCR0A = 0;// set entire TCCR2A register to 0
TCCR0B = 0;// same for TCCR2B
TCNT0 = 0;//initialize counter value to 0
// set compare match register for 2khz increments
OCR0A = 124;// = (16*10^6) / (2000*64) - 1 (must be <256)
// turn on CTC mode
TCCR0A |= (1 << WGM01);
// Set CS01 and CS00 bits for 64 prescaler
TCCR0B |= (1 << CS01) | (1 << CS00);
TIMSK0 |= (1 << OCIE0A);
}//end setup
ISR(TIMER0_COMPA_vect){//timer0 interrupt 2kHz toggles pin 8
//generates pulse wave of frequency 2kHz/2 = 1kHz (takes two cycles for full wave- toggle high then toggle low)
state = digitalRead(5);
Serial.println(toggle1); //reads input and outputs it to serial at 2kHz.
void loop(){
One more quick question about the serial monitor, I have the arduino outputting data to the serial monitor at 8kHz now yet when I have the serial monitor at 115200 bps it still can’t seem to keep up. Are there any tricks to get a higher bps serial reading?
Okay, so what is another method of sampling and recording data at over 2kHz? I am simultaneously using a Raspberry Pi and seeing if the RP is capable(easier) at doing what I need.
