I´m going to try explain the problem that I have with my project.
I try to send data from USB to some Arduinos at the same time via serial port with 2 wire cables (RX + GND) using an Arduino MEGA the intermediate to re-send this data to these Arduinos . But nothing works…
How can I do this? (USB data → Arduino MEGA re-send data → Arduinos Slaves)
This is the code for the “Arduino Slave”. This code works great if I connect this Arduino Slave directly to USB (some digitalWrite for LEDs on the setSlat and setCue are not declare now, just for save space), but I want to use 30+ arduinos that recive this data from the Arduino MEGA via 2 long wire cable (RX + GND) o something similar.
This are the bytes send from the USB to understand a little more the code (it is not my code):
No, I don't see this examples but are so great, I will test this. Thank you.
groundFungus:
Consider RS-485 on the hardware side. It is meant for multi-drop serial over long wires.
I don't considerer RS485 because I don't have idea of it. The RS485 is amazing! I bought one USB to RS485 and one MAX485 to make some test with the Arduino.
I will post the result of the test. Thank you so much.
