Great Code, thank you very much!
I have made some changes to my needs and have put the if(Serial.available() >0 part in the ISR:
//### RS232 ISR ###############################################################
void serialEvent(){ // Serial rx-ISR
while(Serial.available() > 0) { // read in RS232
char x = Serial.read();
// the order of these IF clauses is significant
if (x == endMarker) {
readInProgress = false;
newDataFromPC = true;
inputBuffer[bytesRecvd] = 0;
parseData(); // Parse Command and Values
updateData_reply(); // Process according to Command
if(readInProgress) {
inputBuffer[bytesRecvd] = x;
bytesRecvd ++;
if (bytesRecvd == buffSize) {
bytesRecvd = buffSize - 1;
if (x == startMarker) {
bytesRecvd = 0;
readInProgress = true;
}//if(Serial.available() > 0) {
}//void serialEvent()
parsedata() is pritty much the same, except: I have added to parse 3x int and 1x float:
//### ParseData() #############################################################
void parseData() { // split the data into its parts: 3x int, 1x float
char * strtokIndx; // this is used by strtok() as an index
strtokIndx = strtok(inputBuffer,","); // get the first part - the string
strcpy(comandFromPC, strtokIndx); // copy it to comandFromPC
strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
val1 = atoi(strtokIndx); // convert this part to an integer
val2 = atoi(strtokIndx); // convert this part to an integer
val3 = atoi(strtokIndx); // convert this part to an integer
val4 = atof(strtokIndx); // convert this part to a float
}//void parseData() {
the update Data and reply is changed to:
//### UpdateData and Reply() ##################################################
void updateData_reply() { // Process according to Command
if (newDataFromPC) {
newDataFromPC = false;
// this illustrates using different inputs to call different functions
// LED12 Command
if ((strcmp(comandFromPC, "LED12") == 0)||(strcmp(comandFromPC, "led12") == 0)){
if(val1>0) { Don(12); SPLF("LED12 switched on.");}
else { Doff(12); SPLF("LED12 switched off.");}
}//if ((strcmp(comandFromPC, "LED12") == 0)||(strcmp(comandFromPC, "led12") == 0)){
// FCN Command
else if((strcmp(comandFromPC, "FCN") == 0)||(strcmp(comandFromPC, "fcn") == 0)){
// ...do something with FCN/fcn
reply2pc(); // Send standard answer to RS232
}//else if((strcmp(comandFromPC, "FCN") == 0)||(strcmp(comandFromPC, "fcn") == 0)){
// any other unknown Command
else{
SPLF(" Command unnkown!\n try: \"<COMMAND, Int1, Int2, Int3, Float>\"");
SPLF(" e.g.: <LED12,1> to switch LED on Pin 12 on ('0' = off)");
}//else
}//if (newDataFromPC)
}//void updateData_reply() {
so that the loop() is pretty empty:
//### Loop() ##################################################################
//...add your Code here
LED13tog(); // toggle LED 13 to show its alive
delay(500); // just a delay to simmulate load
}//loop()
and setup, just for the sake of completeness:
#include "myHelpers.h" // my defines for SP, LED13, D i/o
//### Serial Parse global Variables ##########################################
const byte buffSize = 20; // Serial recive Buffer size [Byte]
const byte cmdSize = 10; // Serial recive Command size [Byte]
char inputBuffer[buffSize]; // Serial Buffer
const char startMarker = '<'; // Start Marker
const char endMarker = '\n'; // End Marker
byte bytesRecvd = 0; // Received bytes
boolean readInProgress = false; // still reading in
boolean newDataFromPC = false; // finished reding, new Data received
char comandFromPC[cmdSize] = {0}; // Command buffer
int val1 = 0; // 1.st integer from PC
int val2 = 0; // 2.nd integer from PC
int val3 = 0; // 3.rd integer from PC
float val4 = 0.0; // 4.th Float from PC
//### Setup() #################################################################
SPsetup(); // Serial Setup and print Start-Info
LED13Setup(); // LED13 Setup
DO(12); // Set Digital Output Pin 12 (LED12)
SPL();
SPLF(" Beispiel 4x Serial-Parse\n Type: \"<COMAND, INTEGER_1, INTEGER_2, INTEGER_3, FLOAT_x.yz>\"");
}//setup()
myHelpers.h is just defining SP / SPL / SPLF as Serial.print/ln(F(... and LED13on/off/toggle
Thanks again, for the great, short and efficient code!!
_150627_Test_Serial_Parse_V003.ino (5.25 KB)
myHelpers.h (4.28 KB)
