Re: Set loop condition (while,do...while)
I use infrared sensors to detect my AGV number of turns the wheel, here is my program, the problem is I made ??a mark on the wheel design, the program will do the counting of the action, I want to control the wheels turn a few laps My program does not do, ask where there are problems, please tell me thank you. (The following program has an infrared sensing program forward and backward counting and AGV).
My program two inside while back how to write before they can read the number of wheel revolutions, I want the wheels turn forward it three times and then again three times.
1.program
const int PIRSensor = 2;
int val = 0;
  pinMode(PIRSensor,INPUT);
  pinMode(13,OUTPUT);
void loop(){
  int i;
  i = digitalRead(PIRSensor);
  if(i == LOW){
  digitalWrite(13,HIGH);
  val += val + 1;
   Serial.print(val);
2.program
int val = 0;
  pinMode(PIRSensor, INPUT);
  pinMode(9, OUTPUT);
  pinMode(11, OUTPUT);
  pinMode(DAC0, OUTPUT);
  pinMode(DAC1, OUTPUT);
  int t;
  t = digitalRead(PIRSensor);
  do {
  digitalWrite(9, LOW);
  analogWrite(DAC0, 110);
  digitalWrite(11, LOW);
  analogWrite(DAC1, 110);
  [b]while[/b]?
  do {
    digitalWrite(9, HIGH);
    analogWrite(DAC, 110);
    digitalWrite(11, HIGH);
 [b] while[/b]?
Code tags, please.
http://forum.arduino.cc/index.php?topic=148850.0
  val += val + 1;
So, val starts at 0. val + 1 is 1, so val is incremented by 1, to 1. Then, val + 1 is 2, so val is incremented by 2, to 3. Then, val + 1 is 4, so val is incremented by 4, to 7.
Is that what you want?
Reading the state of an encoder (homemade) once a second hardly seems like a good idea. GET RID OF THE STUPID DELAY!
You almost certainly do not want to be using do/while. You might want to use a while loop, but I doubt it. It isn't clear what you want to do in the while loop, or what the start or termination condition is.
  val += val + 1;
Arguable val is undefined now, but I'm not sure.
This is undefined:
val = val++;
I suggest you rewrite it as:
val++;
This is undefined:
Mmmm in C and it is C after all, all bar 40 years old it should no longer be undefined, but I tried the following code and got results that I did not expect .... will now go and .....
int i;
  i=0;
  Serial.print("i= ");
  Serial.println(i);
  i=0;
  i++;
  Serial.print("i= (will be 1) )");
  Serial.println(i);
  i=0;
  i=i++;
  Serial.print("i= (will be 1) ");
  Serial.println(i);
  i=0;
  i+=i;
  Serial.print("i= (should be 1) ");
  Serial.println(i);
  i=0;
  i+=i+1;
  Serial.print("i= (should be 2) ");
  Serial.println(i);
results
i= 0
i= (will be 1) )1
i= (will be 1) 1
i= (should be 1) 0
i= (should be 2) 1
But as a rule of thumb for any language the rules are (in order of application)
RHS first then LHS,
unary before binary
() then * and / then + and - in that order,
left to right
Mark
i=0;
  i+=i;
  Serial.println(i);
This is just adding 0 to itself.
i = i++;
The above is undefined.
holmes4:
There are some incorrect assumptions there:
  i=0;
  i=i++;
This is actually undefined behaviour since a variable may be modified only once per expression.
  i=0;
  i+=i;
Nope, should be 0 (and is).
0 + 0 = 0 :wink:
  i=0;
  i+=i+1;
Nope, this should be 1 (and is).
(0 += (0+1)) = 1
@int2str
So your saying that the LHS of the = is evaluated before the RHS? IF so can you give a ref in the C/C++ standard or is this just a "side effect" or just the way gcc doe's it and therefore is as Nick puts it undefined? .
Given the size and detail of the C/C++ standard and the nit picking detail I just don't believe that anything is "undefinded".
Mark
holmes4:
No, I'm not saying that at all.
Which example are you referring to?
The C++ standard states that a variable shall be modified only once between sequence points.
"i = i++;" is modifying the variable twice. The standard does not allow for this to happen. So any compiler that allows this and doesn't throw an error is by definition implementing "undefined behaviour".
gcc is even nice enough to warn you about it, if you enable all warnings:
$ g++ -W -Wall -pedantic var.cpp
var.cpp: In function ‘int main()’:
var.cpp:7:12: warning: operation on ‘i’ may be undefined [-Wsequence-point]
holmes4:
Things are indeed undefined in the standard, in order to allow compiler-writers the latitude to improve execution speed. For example:
i = i++ + i++;
That could have all sorts of results, and if the result was not simply "undefined" you might have to put in slower code to make sure it was defined and gave a predictable result.
More stuff about undefined things:
Code:
i = i++ + i++;
To be this is not undefined, the rule are there , uniary op's first (eg ++) then binary ops eg + and () overrides all else this along with left to right (is equal priority) always resolves the RHS.
What I seem to have wrong is = as in (complex LHS = (rhs)) but assuming I'm wrong in saying that the LHS is done before the RHS but that the left to right rule applies because the = is the highest priority operator then it explains the results of my little program and nothing is "undefined"
But it's not a unary arithmetic op; it's a full expression that modifies the variable. Furthermore "i++" is POST-increment, so it's specifically defined to do the increment LATER. An unary op would be like "-i" does not modify the variable, so the "unary first" rule works fine.
For more fun, consider what would be different, based on your rules, between:
  i += i++;
  i += ++i;
holmes4:
Code:
i = i++ + i++;
To be this is not undefined, the rule are there , ...
Yes but when does the post-increment actually increment i? After the first i++? After the second i++? Before storing the result into i? Or afterwards?
holmes4:
Nope, sorry, both "i = i++..." and "i++ + ++i" are expressly prohibited by the standard and thus any usage of it is completely undefined. The compilers can do whatever they want with that, format your hard drive, call your mother-in-law, or whatever.
It's at your own peril to use undefined behaviour and there is really no good reason to do so.
