Re '...several things at the same time'
I've just ran Robin2's comprehensive sketch from the thread, 'Demonstration code for several things at the same time'.
https://forum.arduino.cc/index.php?topic=223286.90
There seem to be no comments in the last six years so I'm therefore posting here instead.
I intend to step through this carefully as a great potential learning exercise asap. But it all appears to work as intended - except for the button.
I'm using the familiar four pin NO breadboard button, which goes low on pressing. It behaves erratically here and I'm wondering if there's a likely explanation I've missed please? The button is physically OK, and has been working fine with other sketches today, although I tried another to be sure.
My code is unaltered from the original apart from pin numbers and a few formating changes. But it takes the post over the site's limit, so I've attached the file:
SeveralThingsCode.ino (9.36 KB)
Please post the file as an attachment. It's hard to imagine, though, how the demonstration code could exceed the limit.
aarg:
Duly attached.
I think the message said something like "...exceeds the 9,000 character limit."
void readButton() \\ FUNCTION
    // this only reads the button state after the button interval has elapsed
    // this avoids multiple flashes if the button bounces
    // every time the button is pressed it changes buttonLed_State causing the Led to go on or off
    // Notice that there is no need to synchronize this use of millis() with the flashing Leds
    if (millis() - previousButtonMillis >= buttonInterval)
        if (digitalRead(buttonPin) == LOW)
            buttonLed_State = ! buttonLed_State; // this changes it to LOW if it was HIGH
            // and to HIGH if it was LOW
            previousButtonMillis += buttonInterval;
what happens if the button is held down for longer than the buttonInterval?
a button action is normally performed when there is a change in button state and it is pressed (i.e. LOW)
void updateOnBoardLedState() \\ FUNCTION Don't do that!
gcjr:
buttonInterval is so long that it would toggle continuously every 300ms. I suppose it's coded simplistically in order to keep the sketch focused on the multitasking aspect...
TheMemberFormerlyKnownAsAWOL:
Don't do that!
Indeed! Corrected that earlier but then attached the previous draft. Now corrected.
I really don't see any question! What is it?
gcjr:
It blinks repeatedly.
What is your question?
aarg:
It's the sentence with the question mark at the end!
Terrypin:
If you mean the remark about the button behaviour, that's been answered... in reply #3 and #5.
aarg:
I don't think either of those explain the erratic behaviour I get. As I said in my #8 reply to Greg, it does blink if I hold the button down. But with a normal brief press/release its action is unpredictable. I note that Robin used a simple wire...
Has anyone tried it?
Terrypin:
Please list the lines on which you made changes - it is much easier to help if you limit your changes to those that are unaviodable.
Please also explain what you mean by "behaves erratically"
...R
Terrypin:
shouldn't it only toggle if the button is pressed? then check for a change in state, not simply that the button is LOW
int lastswitchstate = HIGH;
int ledPin          = 13;
int switchpin       = A1;
void setup () {
    Serial.begin (9600);
    pinMode (ledPin, OUTPUT);
    pinMode (switchpin, INPUT);
void loop () {
    int reading = digitalRead (switchpin);
    if (reading != lastswitchstate){
        lastswitchstate = reading;
        if (LOW == reading)
            digitalWrite (ledPin, ! digitalRead (ledPin));
        delay (10);
Robin2:
...R
As I said, the changes were trivial: pin numbers and some formatting. I just changed my pin numbers back to yours and ran your sketch and obviously I got the same behaviour from the button.
Not sure what I can add to 'erratic' and 'unpredictable'! IOW, sometimes a press does nothing, sometimes it toggles, sometimes it appears to flash very briefly twice on one press. Etc.
Can you confirm that you get clean toggling please?
Terrypin:
Thinking about that code:
The button is only checked once every 300mS. It's entirely possible you would press the button and release it between checks:
                  V-check        V-check ...
CHECKS:     ------|--------------|--------------|--------------|--------------|--- time in mS
PRESSES:             *--------* <-- missed
Not sure why you might see very brief double flashes. I think the idea for the demo is that you press and hold the button for 2 or 5 or whatever seconds, not just for a quick blip.
If you want to toggle the LED using that method you need to change the buttonRead code to look for a change of state and read it much more often (like every 50mS, for example.)
he's not checking for a press. he's checking if the button is LOW
gcjr:
Yes, once every 300mS so a press has to be long and deliberate to demonstrate the blinking timing.
Blackfin:
It's a long time since I wrote and tested the Tutorial code. I don't recall needing to hold the button press for long but it might be a good idea to change
const int buttonInterval = 300; // number of millisecs between button readings
to
const int buttonInterval = 50;
...R
