Re: Using BLE on the R4
esp32 can do classic Bluetooth but I think the firmware on Uno R4 WiFi doesn't support it.
on boards with NINA it is possible to replace the firmware with a simple sketch
I have used this proprietary app:
I haven't used it a lot and didn't spend much time looking at the alternatives, but I see LightBlue mentioned often when this sort of subject comes up. I would prefer an open source alternative, but other than that my experiences using the app have been perfect.
The alternative (also proprietary) I see mentioned by Arduino community members is nRF Connect:
I haven't tried nRF Connect.
It took me a long winter to learn how to use Bluetooth/ BLE. It is NOT as easy as a "serial" connection. The 'peripheral' needs custom code, so does the 'central' AND they need to match.
I worked on a different platform (Sparkfun Artemis) but with ArduinoBLE.
BLE (Bluetooth Low Energy) is even the easier / lighter form, used by most devices.
The ArduinoBLE does not have a lot of examples and none with a 'central' running on another platform.
If you look at apollo3/ArduinoBLE_special at master · paulvha/apollo3 · GitHub and focus on the examples. There are a larger number of examples and some that use BME280 or SPS30 or switch input/output where a 'central' is running on Ubuntu and/or Android. For the latter you will need to install Android Studio and study that as well.
I could be wrong, but I believe that the ESP32-S3 on these boards only support BLE.
At least that was what mentioned in the thread:
My question is Does the R4 UNO WiFi Board start BLE transmissions as soon as it gets powered ..? If so can it be identified by any BLE scanner app? I powered my R4 by a standard external power supply and tried to detect its BLE transmission using BLE scanner mobile app available in Google Play Store. I kept my mobile near R4 but it could not detect. That is why this basic question.
Thank you all! I'd be lost without forums.
I'm trying to drive two dc motors with a ps4 or Xbox controller.
