Re-writeing library's
Ok i have an Ardueno Uno Board, and i bought a GLCD, useing the KS0108 Graphics LCD library, and i would like to add an eathernet shield to the board, but i need to change some pin's. I have gone through the library's and i cant seem to find it. Can someone help me rewrite them to work, if its even possable? :-?
The beauty of the GLCD library is that you specify the pins in the constructor. So, you can use any pins that the ethernet shield is not using, without needing to change any libraries.
Changing the ethernet library requires more than a code editor. It also requires a soldering iron.
But last time i checked im not using any constructor, that i know of (Still a bit new with classes) can i get an example code?
If you can successfully display data on the LCD, then you used a constructor, whether you were aware of it or not.
I have an Ardueno Uno Board, and i bought a GLCD, useing the KS0108 Graphics LCD library,but these problems I have not encountered.
