I wanted a delay of (500-1000 ms) before the led lights up when I press the button, I used the random function for this, but when I tried even with a simple delay of 1000 ms, nothing happens, however the led lights up on button press (when delay is not there in the code).
smkuls:
int pbIn =4;
int ledOut = 7;
int button = 0;
long randNumber;
pinMode(pbIn, INPUT);
pinMode(ledOut, OUTPUT);
button = digitalRead(pbIn);
digitalWrite(ledOut, LOW);
randNumber = random(500, 1000);
delay(randNumber); // If you wanted a delay of (500-1000 ms) you have use delay
if (button == LOW)
digitalWrite(ledOut, HIGH);
// delay(1000);
delay(randNumber); // or here
you have to put delay() function out side the If()
This doesn't seem to be doing anything relating to reaction times at the moment and I'm not entirely clear what behaviour you're trying to achieve, but currently you turn the LED off at the top of loop() so even if you turn it on it will only be on for a couple of microseconds.
My guess is you want something similar to this sequence:
Wait for a random interval.
Turn the LED on.
Wait for button to be pressed and released.
Turn LED off.
Repeat.
PeterH:
Turn the LED on.
Turn LED off.
Repeat.
Is that the general idea?
Hi all, I would like to make a reaction test game but am having trouble getting my head round it even though I am sure it is very simple to sort out.
I'd like to do the following...
the game / loop starts
you wait for an LED to light up after a random time (say within 3 secs of startup)
then you have a 1 sec window (for example) within which you have to press a button
if you press the button in time then something indicates that you are successful
if you don't press it quick enough then something tells you that you failed
then it starts again
Now I have managed to code something (which is down below) based on the BlinkWithoutDelay example that can detect when a button is pressed and when it is released, and then do something depending on what the time difference turns out to be, but it's not quite what I am after.
I'm thinking using interrupts might be in order, to have button push detection running in the background, but I don't know. Any advice is greatly appreciated.
Interrupts are not necessary for this problem. The approach you are taking seems sensible to me, and at first glance that code looks OK. In what way is it 'not quite what I am after'?
Thanks PeterH, I wanted the button pressing bit to be prompted by a light coming on and couldn't work out the order things had to happen in the loop.
A friend advised me though and I have the following. However, the success LED (ledPinYes) comes on regardless of whether I press the button or not, although it does work when I press the button in time. Getting there though...
int buttonPin = 2;
int ledPin = 10;
int ledPinYes = 9;
int ledPinNo = 9;
pinMode(buttonPin, INPUT);
pinMode(ledPin, OUTPUT);
pinMode(ledPinYes, OUTPUT);
pinMode(ledPinNo, OUTPUT);
// start game, reset all displays
digitalWrite(ledPin, LOW);
digitalWrite(ledPinYes, LOW);
digitalWrite(ledPinNo, LOW);
// wait until the buttons are released
while (digitalRead(buttonPin)) {
// do nothing
// random delay 1-4 seconds
int random_delay = 1000 + random(3000);
delay(random_delay);
// turn on led
digitalWrite(ledPin, HIGH);
// can adjust this reaction time, current time plus a sec
long failtime = millis() + 1000;
int success = false;
while (millis() < failtime) {
if (digitalRead(buttonPin)) {
success = true;
if (success) {
digitalWrite(ledPinYes, HIGH);
else {
digitalWrite(ledPinNo, HIGH);
// hold the success/failure display for a few seconds
delay(3000);
I am new to the world of Arduino, I work on a system that measures and displays the response time of an athlete, for that I must use 7 LED that light up in a random manner or on a selected sequence and each time an lED is on the athlete must hit the corresponding plate to turn off the lED and measured the time between switching on and off of the led, I'm between using a piezoelectric sensor as the impact sensor or a proximity sensor
thank you for supporting me
