Reaction value(?) of MPU6050's acceleration
Hello,
I have a question about the acceleration of a MPU6050 sensor.
When the sensor moving ahead(positive way), I’d got a negative value of acceleration from the senor at the beginning part, as a photo.
I wonder whether there are something wrong with my sensor, because
at here(https://developer.mbed.org/users/aberk/notebook/dead-reckoning/), they got a positive value at starting point when the sensor moving to positive way.
You have not provided enough information for anyone to guess if there actually is a problem.
That look exactly like what u'll get trying to move the sensor by hand.. over a 3cm distance... FAST.
jremington: You have not provided enough information for anyone to guess if there actually is a problem.
What information do you need?
wkdxoghdi: What information do you need?
Evidently, you didn't read the "How to use this forum" post.
jremington:
Evidently, you didn’t read the “How to use this forum” post.
I just use MPU6050 example code,(http://playground.arduino.cc/Main/MPU-6050?action=sourceblock&num=1)
and the hereinbefore image shows y-axis acceleration.
// MPU-6050 Short Example Sketch
// By Arduino User JohnChi
// August 17, 2014
// Public Domain
#include<Wire.h>
const int MPU_addr=0x68;  // I2C address of the MPU-6050
int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
void setup(){
  Wire.begin();
  Wire.beginTransmission(MPU_addr);
  Wire.write(0x6B);  // PWR_MGMT_1 register
  Wire.write(0);     // set to zero (wakes up the MPU-6050)
  Wire.endTransmission(true);
void loop(){
  Wire.write(0x3B);  // starting with register 0x3B (ACCEL_XOUT_H)
  Wire.endTransmission(false);
  Wire.requestFrom(MPU_addr,14,true);  // request a total of 14 registers
  AcX=Wire.read()<<8|Wire.read();  // 0x3B (ACCEL_XOUT_H) & 0x3C (ACCEL_XOUT_L)
  AcY=Wire.read()<<8|Wire.read();  // 0x3D (ACCEL_YOUT_H) & 0x3E (ACCEL_YOUT_L)
  AcZ=Wire.read()<<8|Wire.read();  // 0x3F (ACCEL_ZOUT_H) & 0x40 (ACCEL_ZOUT_L)
  Tmp=Wire.read()<<8|Wire.read();  // 0x41 (TEMP_OUT_H) & 0x42 (TEMP_OUT_L)
  GyX=Wire.read()<<8|Wire.read();  // 0x43 (GYRO_XOUT_H) & 0x44 (GYRO_XOUT_L)
  GyY=Wire.read()<<8|Wire.read();  // 0x45 (GYRO_YOUT_H) & 0x46 (GYRO_YOUT_L)
  GyZ=Wire.read()<<8|Wire.read();  // 0x47 (GYRO_ZOUT_H) & 0x48 (GYRO_ZOUT_L)
  Serial.print("AcX = "); Serial.print(AcX);
  Serial.print(" | AcY = "); Serial.print(AcY);
  Serial.print(" | AcZ = "); Serial.print(AcZ);
  Serial.print(" | Tmp = "); Serial.print(Tmp/340.00+36.53);  //equation for temperature in degrees C from datasheet
  Serial.print(" | GyX = "); Serial.print(GyX);
  Serial.print(" | GyY = "); Serial.print(GyY);
  Serial.print(" | GyZ = "); Serial.println(GyZ);
  delay(333);
Reread reply #2. Maybe you have the sign wrong on the acceleration.
