// Started this new thread after posting to a year old thread
I bought a FRAM module on ebay , it is based on a FM24CL16B chip and is 16 kilobits ( 2 K bytes obviously ) ( more here http://www.waveshare.com/wiki/FM24CLXX-FRAM-Board_Datasheets )
After trying 3 or 4 FRAM 'libraries', including a failed attempt at the supplied code from above website (was C code, but not 'IDE'), I found code (by casemod) and it works up to 256 bytes !!
May I please ask how to extend the code to 2048 bytes?
The datasheet (attached) for the FM24CL16Bchip says that the FRAM memory is organised as 8 pages of 256 bytes each, so the attached code seems to be working for page 0.
The datasheet states that the pages are addressed by setting A2,A1,A0 in the slave address.
The slave address 8 bit format is 1 0 1 0 A2 A1 A0 R/W
Where 1010.... is the I2C address i.e 0x50 or decimal 80. ( So A2=A1=A0=0 so page is 0 ...I guess)
I have interpreted that to get to page 1, A0 must be set to 1, so the slave address is 0x51.
Hence page 2 is 0x52 ..... and page 7 is 0x57.
I understand that the R/W bit must be set 1 or 0 for read or write and am trusting it is already working in the code as it does work.
So for testing I replaced the following code from casemod's code
#define DEVICEADDRESS 0x57
Wire.beginTransmission(DEVICEADDRESS);
Wire.write(theMemoryAddress);
with
#define FRAMADDRESS 0x57
FramAddress = FRAMADDRESS + int( theMemoryAddress / 256 ); // Converts theMemoryAddress to FRAMaddress + page address
WordAddress = theMemoryAddress % 256; // Converts theMemoryAddress to word address
Wire.beginTransmission(FramAddress);
Wire.write(WordAddress);
where memory address is any of 0 to 2047
but it does not work above 256 bytes - it looks like A2,A1,A0 are ignored.
Incidentally, while testing I had one time had FRAMADDRESS = 0x50 instead on 0x57 and got the same result. Only the first 256 bytes are writeable/readable. I am not entirely sure which is the correct I2C address but datasheet implies 0x50.
Any advise please, please consider me a wire.h newb, as I usually rely on libraries?
Thanks
/// casemod code which works for first 256 bytes //////////
#include <Wire.h>
//int temp = 0;
uint16_t temp = 0;
uint16_t test = 0b1111100101011000;
Wire.begin();
EepromWrite(0x05, test);
temp = EepromRead(0x05);
Serial.println(temp, BIN);
//Serial.println(temp1, BIN);
delay(2000);
void EepromWrite(uint8_t theMemoryAddress, uint16_t u16Byte)
uint8_t lowByte = ((u16Byte) & 0xFF);
Serial.println(lowByte);
uint8_t highByte = ((u16Byte >> 8) & 0xFF);
Serial.println(highByte);
Wire.write(lowByte);
Wire.write(highByte);
Wire.endTransmission();
uint16_t EepromRead(uint8_t theMemoryAddress)
Wire.requestFrom(DEVICEADDRESS,2);
uint8_t lowByte = Wire.read();
uint8_t highByte = Wire.read();
return ((lowByte) & 0xFF) + ((highByte << 8) & 0xFF00);
FM24CL16B.pdf (282 KB)
