Read analog input and turn on relay for 30 minutes without using delay
HI,
I am making device which needs to turn on relay and keep running it for 30 minutes after some analog pin reads less voltage. I don’t want to use delay to achieve 30 minutes because arduino is dead for that time, and it can not react if state on that analog pin changes
Here is my version of code:
int led =13;      //signalna led dioda
int pumpa =10;   //izlaz za pumpu
#include "Timer.h"
Timer t;
float vout = 0.000;    //
float vin = 0.000;    //
float R1 = 100000.0; // Otpornost R1 (100K)   ovaj delitelj za napone do 30v
float R2 = 10000.0; // Otpornost R2 (10K)     ovaj delitelj za napone do 30v
int value = 0.00;
// setup //
pinMode(led, OUTPUT);
pinMode(pumpa, OUTPUT);
t.pulse(pumpa, 30 * 60 * 1000, HIGH); // 30 minutes
digitalWrite(led, HIGH);
//digitalWrite(pumpa, HIGH);
delay(100);
Serial.println (vin);   //ispiši i pošalji vrednost napona na serijski port
value = analogRead(A0);   //pročitaj vrednost napona na portu A0
vout = (value * 5.0) / 1024.0; // izračunaj vrednost napona
vin = vout / (R2/(R1+R2));
//  USLOV  //
if (vin < 05.00)       //Isključi rele na portu 10 ako je napon na portu A0 manji od 5v
 t.update();
 digitalWrite(led, HIGH);    // uključi signalnu LED
else if (vin > 05.00)  //Uključi rele na portu 10 ako je napon na portu A0 veći od 5v
 t.stop(pumpa);
 digitalWrite(led, LOW);
 digitalWrite(pumpa, LOW);
Problem is that this does not work,
Any suggestion?
Regards
zoomtronic
I don't wanna use delay
But . . . you do!delay(1000);
Look at the blink without delay example in the IDE to see how to time events without using delay().
Yes I do use it for one second, but I don't want to use it for 30 minutes
Get the code right, and you don't need to use it all.
(BTW, we say "want to", not "wanna")
Ok, thanks for writing correction
'millis()' is easy enough to use without the "Timer" library, but if you still want to use it, I think you need to move 't.update();' out of the 'if' conditional statement to the main body of the 'loop()' function.
