Hi !
I have a problem with the Analog input. I want to build a Arduino audio input (https://www.instructables.com/Arduino-Audio-Input/) but, i want the controller some parameters with using a potentiometer with the analog input.
I used the code in PedalShield Electrosmashb prototype .
// [www.Electrosmash.com/rights](http://www.electrosmash.com/rights) CC-by-NC
//defining hardware resources.
#define LED 13
#define FOOTSWITCH 12
#define TOGGLE 2
#define PUSHBUTTON_1 A5
#define PUSHBUTTON_2 A4
//defining the output PWM parameters
#define PWM_FREQ 0x00FF // pwm frequency - 31.3KHz
#define PWM_MODE 0 // Fast (1) or Phase Correct (0)
#define PWM_QTY 2 // 2 PWMs in parallel
//other variables
int input;
unsigned int ADC_low, ADC_high;
//setup IO
pinMode(FOOTSWITCH, INPUT_PULLUP);
pinMode(TOGGLE, INPUT_PULLUP);
pinMode(PUSHBUTTON_1, INPUT_PULLUP);
pinMode(PUSHBUTTON_2, INPUT_PULLUP);
pinMode(LED, OUTPUT);
pinMode(6, OUTPUT); //PWM0 as output
pinMode(7, OUTPUT); //PWM1 as output
// setup ADC
ADMUX = 0x60; // left adjust, adc0, internal vcc
ADCSRA = 0xe5; // turn on adc, ck/32, auto trigger
ADCSRB = 0x00; //free running mode
DIDR0 = 0x01; // turn off digital inputs for adc0
// setup PWM
TCCR4A = (((PWM_QTY - 1) << 5) | 0x80 | (PWM_MODE << 1)); //
TCCR4B = ((PWM_MODE << 3) | 0x11); // ck/1
TIMSK4 = 0x20; // interrupt on capture interrupt
ICR4H = (PWM_FREQ >> ![8)|20x20])
ICR4L = (PWM_FREQ & 0xff);
DDRB |= ((PWM_QTY << 1) | 0x02); // turn on outputs
sei(); // turn on interrupts - not really necessary with arduino
//Turn on the LED and write the OLED if the effect is ON.
if (digitalRead(FOOTSWITCH))
digitalWrite(LED, HIGH); //light the LED
digitalWrite(LED, LOW); // switch-off the LED
ISR(TIMER4_CAPT_vect)
// get ADC data
ADC_low = ADCL; // you need to fetch the low byte first
ADC_high = ADCH;
//construct the input sumple summing the ADC low and high byte.
input = ((ADC_high << ![8)|20x20]| ADC_low) + 0x8000; // make a signed 16b value
/** READ THE A1 , A2 AND A3 PIN */
//write the PWM signal
OCR4AL = ((input + 0x8000) >> "); // convert to unsigned, send out high byte
OCR4BL = input; // send out low byte
I am conected the potentiometer in the A1, A2 and A3 input.
The question is... How can read the value in the potentiometer ?? Because i cannot used the analogRead function.... Can??
Thanks in advance
Jota
