Read and Write Eeprom Problem, Programming Atmega32 with Arduino IDE
i have test the Eeprom Library, work perfectly in Arduino uno and Proteus Simulation, but cant read/write in ATmega 32 with custom development board.
Anyone can give me a sample code, how to Read and Write Eeprom via Programming Atmega32 with Arduino IDE?
thanks
Are you using MightyCore?
What exactly do you mean by "cant read/write"?
the program cant write or read value from Eeprom,
i used this
the librrary used this
You didn't really answer either of my questions.
Most importantly:
pert:
Which hardware package are you using?
zifank:
i used this
Woah, old school! Did you make that?
zifank:
https://github.com/ryantenney/EEPROMex/blob/master/EEPROMex.h
Why would you use that? The EEPROMex is completely obsolete and even worse you're using an outdated version of the library.
pert:
Most importantly:Which hardware package are you using?
1, no, i don't use MightyCore,
2. yes, very old school.. :wink:
3. what the best or newest library for use Eeprom for Programming Atmega32 ?
thanks pert..
zifank:
The Arduino IDE doesn't have built-in support for an ATmega32-based board. So you must have done something to add support for the ATmega32. So tell me what you did and then I can answer your question.
First, i have a 3 variable o write a code to write to eeprom in arduino uno, use Eepromex.h library with this code :
#include <EEPROMex.h>
int var1;
int var2;
float var3;
int ledpin;
int avar1 =0;; //var 1 address
int avar2 =10;//var 2 address
int avar3 =20;//var 2 address
 pinMode(ledpin, OUTPUT);
 digitalWrite(ledpin, HIGH);
 writeep();
 readep();
 Serial.println(var1);
 Serial.println(var2);
 Serial.println(var3);
void readep(){
 var1 = EEPROM.readLong(avar1);
 var2 = EEPROM.readLong(avar2);
 var3 = EEPROM.readFloat(avar3);
void writeep(){
 EEPROM.writeLong(var1, 8000);
 EEPROM.writeLong(var2, 9000);
 EEPROM.writeFloat(var3, 1.23);
the led used for sign when my development board working with my code;
and upload to Uno. the result work perfectly in Uno.
Next, I try to upload using programmer to gelatino -32 w/Atmega32 with USBasp.
Then the chip move to my development board, and led light normally, but the program can’t read or write internal eeprom, the variable value still zero;
That’s my problem
