Read big array from header file
Hello, How can i read a big array (10k) from a header file? I have an image stored in the h file and all the posts that i found till now are referring to small array stored in flash
Header files get #included into the sketch. Obviously, that header file can not be included, so you have a problem.
What is the data in the array for?
is an 16 bits bmp 80x42 pixels image stored as an array i need to read each pixel and put it on the screen data looks like this
const unsigned short name[] = { 0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000, 0x0000,0x0022,0x0066,0x00AA,0x00EF,0x0154,0x0176,0x0177, 0x0177,0x0177,0x0177,0x0178,0x0176,0x0111,0x00CD,0x0088, 0x0044,0x0022,0x0000,0x0000,0x0000,0x0000,0x0000,0x0020, ........................................................................
What kind of 80 x 42, 16 bit screen are you putting this data on? What does this static image represent?
the lcd is LS020 and hardware is similar to s65 shield the image is a small logo that i want to display on the screen
10k !
What kind of an Arduino monstrosity are you using?
well, i'm using an duemilanove transformed in uno and i have left 11k of free memory...so i decided to put a picture in the free space some pictures of this can be founded here http://grozeaion.com/electronics/high-speed-photography.html
The Uno has 2k of RAM, I think you'll need to use PROGMEM for this array then. :)
But how can i use PROGMEM on an 8-10k array?
It it is helpful i can upload or send by e-mail the h file
This is a new problem that beats me
Serial.println((int)name[2000]);// This work for any any value from the array
unsigned int p=0; //position in name
for(byte i=0; i<79; i++)
for(byte j=0; j<41; j++)
Serial.println((int)name[p]);// this line doesn’t show anything
p++;
What i’m doing wrong here?
What size is name? What type?
const uint16_t name[] = //78*40=3120 items in array { 0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000, 0x0000,0x0022,0x0066,0x00AA,0x00EF,0x0154,0x0176,0x0177, 0x0177,0x0177,0x0177,0x0178,0x0176,0x0111,0x00CD,0x0088, 0x0044,0x0022,0x0000,0x0000,0x0000,0x0000,0x0000,0x0020, 0x0105,0x02CD,0x055A,0x061E,0x065F,0x067F,0x067F,0x067F, 0x065F,0x04B7,0x0146,0x0000,0x0000,0x0000,0x0000,0x0000, 0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000,0x0000, 0x0021,0x0167,0x0371,0x057A,0x05DD,0x063E,0x067F,0x065F, 0x061E,0x03B2,0x00A3,0x0000,0x2040,0x58A0,0xA940,0xB960, 0xC980,0xC980,0xC980,0xC980,0xC180,0x8900,0x0000,0x0000, 0x0000,0x0000,0x0000,0x0000,0x0000,0x0022,0x0089,0x0110, 0x0155,0x0155,0x0111,0x00CC,0x00AA,0x0088,0x0087,0x0088,
You have an 2K RAM, putting more than say 1,7Kb of data in the ram will likely kill your arduino programm because the stack will be corrupted by data and it will just have an erratic behaviour, as said, google for avr progmem and learn how to use it, that will move the data from the ram to the flash memory.
Got it working my stupid assumption was that using PROGMEM the data will be stored in sram sorry for your time wasted with me
http://www.nongnu.org/avr-libc/user-manual/group__avr__pgmspace.html#ga75acaba9e781937468d0911423bc0c35
