Based on this code which returns all text messages that are unread
modem = SerialAT which is Serial1
void Check_Balance()
CheckBalanceCount++; // increment x by one and returns the old value of x
String smsNumber = "2424"; //Skinny is the Operator
String smsMessage2 = "BAL"; //Request the balance of the account
if (CheckBalanceCount >= 80) { //Check balance once a week 604800 300 is 5 minutes
CheckBalanceCount = 0;
modem.sendAT("+CMGD=0,2"); //0 param starting index # mesgs be deleted. 2 param only read messages should be deleted
modem.waitResponse(5000L);
modem.sendAT("+CMGF=1"); //Set the message format to text mode
modem.waitResponse(1000L);
modem.sendAT("+CMGS=\"",smsNumber,"\""); // Send a message to the number 2424
SerialAT.print(smsMessage2); //Write the SMS message
SerialAT.write(CR); // Send the Ctrl+Z character to terminate the message
pDBGln("+CMGS Sent BALANCE request");
//modem.sendAT("+CMGL=\"ALL\""); //All messages
//modem.sendAT("+CMGD=1"); //Read and delete message
modem.waitResponse(5000L); //Wait up to 5 seconds for the message response
modem.sendAT("+CMGL=\"REC UNREAD\""); //Received unread messages e.g. new message
delay(5000);
So this will text 2424 with BAL to then list unread messages
Output is
OK
AT+CMGD=0,2
OK
AT+CMGF=1
OK
AT+CMGS="2424"
+CMGS: 169
OK
AT+CMGL="REC UNREAD"
+CMGL: 0,"REC UNREAD","2424","","23/03/05,13:41:00+52"
Hi! Your Skinny balance is
$11.70 credit
For your account info, text INFO to 2424.
I now want to read the body of the text message and write to a string? So where do I start, my end goal is to check the balance on the SIM as a string to then send via MQTT. So in the out put above is the string was Message I want it to reflect the balance which is 11.70.
Thanks total code is few 1000 lines now and hard to remove private info.
Prints out all messages prior it delete all read so technically only ever one sms unread
Send 2424 BAL to operator and it returns balance
$11.70 credit
So in essence I just want to write 11.70 to a string to use with a MQTT publish.
Assuming that you are capturing the response from the modem in a char array(?)... then you could use something like below, to parse the array and look for the "$" character to locate the amount. Then keep reading until you find the trailing space.
char buffer [] = "Hi! Your Skinny balance is $11.70 credit. For your account info, text INFO to 2424.";
char amount[10];
uint8_t idx = 0;
char * ptr = strstr(buffer, "$") + 1;
while (*ptr != ' ')
amount[idx++] = *ptr;
ptr++;
amount[idx] = '\0';
Serial.println(buffer);
Serial.println(amount);
14:29:44.937 -> AT+CMGF=1
14:29:44.937 ->
14:29:44.937 -> OK
14:29:44.937 -> AT+CNMI=2,1
14:29:44.984 ->
14:29:44.984 -> OK
14:29:44.984 -> AT+CMGS="2424"
14:29:44.984 ->
14:29:44.984 -> >
14:29:47.401 ->
14:29:47.401 -> +CMGS: 2
14:29:47.401 ->
14:29:47.401 -> OK
14:29:47.401 -> +CMGS Sent BALANCE request
14:29:47.401 -> AT+CMGL="REC UNREAD"
14:29:47.492 ->
14:29:47.492 -> +CMGL: 0,"REC UNREAD","2424","","23/03/08,14:27:49+52"
14:29:47.492 -> Hi! Your Skinny balance is
14:29:47.492 -> $11.45 credit
14:29:47.492 -> For your account info, text INFO to 2424.
14:29:47.492 ->
14:29:47.492 -> OK
14:29:47.492 -> AT+CMGRD=0
14:29:47.537 ->
14:29:47.537 -> +CMGRD: "REC READ","2424","","23/03/08,14:27:49+52"
14:29:47.537 -> Hi! Your Skinny balance is
14:29:47.537 -> $11.45 credit
14:29:47.537 -> For your account info, text INFO to 2424.
14:29:47.572 ->
14:29:47.572 -> OK
Revised code which puts the following into message:
15:13:18.068 -> AT+CMGF=1
15:13:18.116 ->
15:13:18.116 -> OK
15:13:18.116 -> AT+CNMI=2,1
15:13:18.116 ->
15:13:18.116 -> OK
15:13:18.116 -> AT+CMGS="2424"
15:13:18.116 ->
15:13:18.116 -> >
15:13:20.800 ->
15:13:20.800 -> +CMGS: 19
15:13:20.800 ->
15:13:20.800 -> OK
15:13:20.800 -> +CMGS Sent BALANCE request
15:13:20.800 -> AT+CMGL="REC UNREAD"
15:13:20.845 ->
15:13:20.845 -> +CMGL: 0,"REC UNREAD","2424","","23/03/08,15:11:23+52"
15:13:20.845 -> Hi! Your Skinny balance is
15:13:20.845 -> $11.45 credit
15:13:20.845 -> For your account info, text INFO to 2424.
15:13:20.845 ->
15:13:20.845 -> OK
15:13:20.845 -> AT+CMGRD=0
15:13:21.954 -> message:
15:13:21.954 -> +CMGRD: "REC READ","2424","","23/03/08,15:11:23+52"
15:13:21.954 -> Hi! Your Skinny balance is
15:13:21.954 -> $11.45 credit
15:13:21.954 -> For your account info, text INFO to 2424.
15:13:21.954 ->
15:13:21.954 -> OK
if (CheckBalanceCount >= 100) { //Check balance once a week 604800 300 is 5 minutes
//modem.sendAT("+CMGD=0,2"); //0 param starting index # mesgs be deleted. 2 param only read messages should be deleted
//modem.waitResponse(5000L);
modem.sendAT("+CNMI=2,1"); //Enable SMS message notifications
//modem.sendAT("+CMGS=\"",smsNumber,"\""); //Send a message to the number 2424
String command = "+CMGS=\"" + smsNumber + "\"";
modem.sendAT(command);
SerialAT.write(CR); //Send the Ctrl+Z character to terminate the message
String data;
modem.waitResponse(5000L); //Wait up to 5 seconds for the message response and store it in the string variable
modem.sendAT("+CMGRD=0"); // Send AT+CMGR command to read the SMS message at index 1 then deletes it
//modem.waitResponse(5000); //Wait up to 5 seconds for the message response
//SerialAT.readString();
data = SerialAT.readString();
Serial.print("message: ");
Serial.println(data);
delay(5000);
Many thanks, will revise but this code is now working
if (CheckBalanceCount >= 86400) { //Check balance once a day 86400 or per week 604800
String data;
String balanceMessage = data.substring(data.indexOf("$")); // extract portion of message that contains balance
balanceMessage.trim(); // remove any leading/trailing white space
float balance = balanceMessage.substring(1).toFloat(); // extract numeric value of balance
Serial.print("Balance: ");
Serial.println(balance);
//mqtt.publish(topicCredit, balance);// Publish Balance to MQTT
mqtt.publish(topicCredit, String(balance).c_str());
delay(5000);
