Read char array, clear it's values and read it again
Hello. I do need some help on my code. Basically what i am trying to do is reading the entered string and outputting correct responses to the entered text. I manage to do that, yet what i cannot do is clear the string so i can enter new data into it and read it again. After each proper sentence (for example: +SIND: 4) the variable "at_buffer" which contains string entered into serial port should reset so that i can enter another sentence into it.
Also 1 thing. The proper sentences start with "+". That means when i enter it 1st, arduino will read + as an empty char. How is it possible to change it that + is read as + ?
I hope you understand my point. Would someone have any ideas on how to make that happen? Thanks.
#define ilgis 90
char at_buffer[ilgis];
char buffidx;
char kint;
Serial.println("Decode is starting");
kint=1;
void readATString(void)
char c;
while (1) {
if(Serial.available() > 0) {
c=Serial.read();
delay(200);
at_buffer[buffidx++]= c;
ProcessATString();
void ProcessATString() {
if( strstr(at_buffer, "+SIND: 8") != 0 ) {
Serial.println("GPRS unavailable");
if( strstr(at_buffer, "+SIND: 11") != 0 ) {
Serial.println("GPRS connected");
if( strstr(at_buffer, "+SIND: 4") != 0 ) {
Serial.println("GPRS AT ready");
if( strstr(at_buffer, "AT+CGATT?") != 0 ) {
if(strstr(at_buffer, "CGATT : 1") != 0 ) {
if(kint > 0){
kint = 0;
if(strstr(at_buffer, "OK") != 0 ){
Serial.println("Waiting for GPRS");
kint = 1;
if( strstr(at_buffer, "AT+CGACT=1,1") != 0 ) {
if(strstr(at_buffer, "OK") != 0 ) {
Serial.println("Activate PDP Context");
while (Serial.available()) {
int c = Serial.read();
if (c) {
readATString();
try this
//clear out param for new param
    memset(&at_buffer[0], 0, sizeof(at_buffer));
not sure what you mean.
Start by using '/0' (null) to terminate your string, this is the normal way of dealing with strings.
Then in readAtString after the call to processAtString set at_buffer[0]='/0'; and buffidx =0;
buffidx should be a byte not a char as its a counter not a character.
Mark
Thanks for response.
I have tried to put this line after each condition sentence yet after this line is executed, string is cleared and i am unable to enter any other data into the array. Or maybe memset should be executed elsewhere? Sorry for silly questions for i am newbie in programming.
mistergreen:
What i mean is when i enter "+SIND: 4" into the serial port, arduino reads it as "SIND: 4" - it reads the "+" char as a gap
holmes4:
Mark
Thanks for information. I have tried out your suggestion yet when i insert those lines after the call to processAtString, the word which is sent from Serial port is read not as 1 word, but as separate chars. For example if i enter "SIND", it is read not 1 time the word "SIND" but 4 times as separate letters "S" "I" "N" "D" and as a result my at_buffer contains only letter D.
I assume i am trying to clear the string in the wrong line on the code. Any thoughts?
Cheers!
ProcessATString();
You need to append a null terminator to the char array in order for it to be used as a c-string. I suggest you do this each time you append a character to it, so that the buffer always contains a well-formed c-string:
at_buffer[buffidx]= '\0';
I suggest you only process the buffer when there is something in it i.e. buffidx > 0, and set buffidx = 0 after you have processed it.
Also, before appending a character to the array, ensure that the array is not already full. Remember to allow space to hold the null terminator, as well as the string itself:
#define ilgis 90
char at_buffer[ilgis+1];
char buffidx;
if(buffidx < ilgis)
  // buffer full
  buffidx = 0;
In this example I've handled the 'buffer full' condition by flushing the buffer, since you don't have any way to detect when a complete message has been received. If you message is expected to be terminated by a newline then I'd rather use that to trigger processing of the message.
Thank you everyone :slight_smile: It seems that i didn't handle the string termination properly. I would like to thank you for pointing that out as it will help not only to work on this project but also in the future.
Thank you guys and cheers!
