Here is a demo of how you might read your file.
This program is complex since it does a lot of error checking GASP!
It is also not well tested.
I plan to post it as an SdFat example.
// Functions to read a CSV text file one field at a time.
#include <limits.h>
#include <SPI.h>
// next line for SD.h
//#include <SD.h>
// next two lines for SdFat
#include <SdFat.h>
SdFat SD;
#define CS_PIN SS
File file;
* Read a file one field at a time.
* file - File to read.
* str - Character array for the field.
* size - Size of str array.
* delim - csv delimiter.
* return - negative value for failure.
* delimiter, '\n' or zero(EOF) for success.
int csvReadText(File* file, char* str, size_t size, char delim) {
char ch;
int rtn;
size_t n = 0;
while (true) {
// check for EOF
if (!file->available()) {
rtn = 0;
if (file->read(&ch, 1) != 1) {
// read error
rtn = -1;
// Delete CR.
if (ch == '\r') {
continue;
if (ch == delim || ch == '\n') {
rtn = ch;
if ((n+1) >= size) {
// string too long
rtn = -2;
n--;
str[n++] = ch;
str[n] = '\0';
return rtn;
int csvReadInt32(File* file, int32_t* num, char delim) {
char buf[20];
char* ptr;
int rtn = csvReadText(file, buf, sizeof(buf), delim);
if (rtn < 0) return rtn;
*num = strtol(buf, &ptr, 10);
if (buf == ptr) return -3;
while(isspace(*ptr)) ptr++;
return *ptr == 0 ? rtn : -4;
int csvReadInt16(File* file, int16_t* num, char delim) {
int32_t tmp;
int rtn = csvReadInt32(file, &tmp, delim);
if (tmp < INT_MIN || tmp > INT_MAX) return -5;
*num = tmp;
return rtn;
int csvReadUint32(File* file, uint32_t* num, char delim) {
char buf[20];
char* ptr;
*num = strtoul(buf, &ptr, 10);
int csvReadUint16(File* file, uint16_t* num, char delim) {
uint32_t tmp;
int rtn = csvReadUint32(file, &tmp, delim);
if (tmp > UINT_MAX) return -5;
*num = tmp;
return rtn;
int csvReadDouble(File* file, double* num, char delim) {
char buf[20];
char* ptr;
*num = strtod(buf, &ptr);
int csvReadFloat(File* file, float* num, char delim) {
double tmp;
int rtn = csvReadDouble(file, &tmp, delim);
if (rtn < 0)return rtn;
// could test for too large.
*num = tmp;
return rtn;
// Wait for USB Serial
while (!Serial) {
yield();
Serial.println("Type any character to start");
while (!Serial.available()) {
yield();
// Initialize the SD.
if (!SD.begin(CS_PIN)) {
Serial.println("begin failed");
return;
// Remove existing file.
SD.remove("READTEST.TXT");
// Create the file.
file = SD.open("READTEST.TXT", FILE_WRITE);
if (!file) {
Serial.println("open failed");
return;
// Write test data.
file.print(F(
"36,23.20,20.70,57.60,79.50,01:08:14,23.06.16\r\n"
"37,23.21,20.71,57.61,79.51,02:08:14,23.07.16\r\n"
// Rewind the file for read.
file.seek(0);
// Read the file and print fields.
int16_t tcalc;
float t1, t2, h1, h2;
// Must be dim 9 to allow for zero byte.
char timeS[9], dateS[9];
while (file.available()) {
if (csvReadInt16(&file, &tcalc, ',') != ','
|| csvReadFloat(&file, &t1, ',') != ','
|| csvReadFloat(&file, &t2, ',') != ','
|| csvReadFloat(&file, &h1, ',') != ','
|| csvReadFloat(&file, &h2, ',') != ','
|| csvReadText(&file, timeS, sizeof(timeS), ',') != ','
|| csvReadText(&file, dateS, sizeof(dateS), ',') != '\n') {
Serial.println("read error");
int ch;
int nr = 0;
// print part of file after error.
while ((ch = file.read()) > 0 && nr++ < 100) {
Serial.write(ch);
Serial.print(tcalc);
Serial.print(',');
Serial.print(t1);
Serial.print(',');
Serial.print(t2);
Serial.print(',');
Serial.print(h1);
Serial.print(',');
Serial.print(h2);
Serial.print(',');
Serial.print(timeS);
Serial.print(',');
Serial.println(dateS);
file.close();
