hi, is possible read with Serial cable connected to COM1 in PC data directly to arduino uno (tx,rx pins?)
or must have RS232 to TTL shield ?
i send via my SW to com port instructions, and i want read and show it on arduino (lcd display on it)
Yes. The voltages from a real RS232 port will damage the Arduino.
A quick & dirty method is this. It doesn't respect the official spec of RS232, but works.
// Per
if you connected the Arduino to the PC using the USB cable.. doesnt it propgate as a COM port?
not sure what 'software' you are using (did you mention?)
but I know things like Python..etc can send data out the com port1...
I have used PHP scripts to do so.. but on a Windows machine the communication is only PHP > UNO.. and NOT UNO >> PHP
I made a (Adobe) Flash gui a while back to use as a front end.. which in turn sent data to a php script that dumped the 'instruction' (RGB values) to the UNO to parse and use as needed.
