read data from labview visa
hi,i have a problem here,how can i read the input data from labview+visa using serial communication and show the result on the serial monitor?
if someone has the tutorial or better experience please help me :slight_smile:
regard,
You can't. You can't use the one serial port to talk to labview and the serial monitor application.
PaulS:
ok thanks for the answer Paul, but how about if i want to read the labview output to arduino,what must i do?
There are port monitoring programs that can run on a pc which will show the traffic on a serial port.
Use Serial.available() to see how much data is available. Use Serial.read() whenever the answer is positive.
thanks for all suggest very helpful
Generally speaking you need to capture the data from labview, then do what is desired with the captured data. below is a simple example.
// zoomkat 8-6-10 serial I/O string test
// type a string in serial monitor. then send or enter
// for IDE 0019 and later
int ledPin = 13;
String readString;
  pinMode(ledPin, OUTPUT);
  Serial.println("serial on/off test 0021"); // so I can keep track
  while (Serial.available()) {
    delay(3);
    char c = Serial.read();
    readString += c;
  if (readString.length() >0) {
    Serial.println(readString);
    if (readString == "on")
      digitalWrite(ledPin, HIGH);
      Serial.println("LED ON");
    if (readString == "off")
      digitalWrite(ledPin, LOW);
      Serial.println("LED OFF");
    readString="";
