Hi everyone, I'm using a ESP32, and I'm trying to read data from the Nextion display.
I've created a "Lift Angle Function" with a default value set to 52 and with the "Button Minus Function" and "Button Plus Function" I can increase or decrease that default value. After increasing or decreasing 52, in the "Button Enter Function" I want to assign the new value to the variable int lift_angle. My question is how do I do that?
I've written there int lift_angle = get LiftAngle;, what's the right syntax
#include <Nextion.h>
Nextion Function
void ButtonMinusPushCallBack(void *ptr);
void ButtonPlusPushCallBack(void *ptr);
void ButtonWeiterPushCallBack(void *ptr);
void ButtonEnterPushCallBack(void *ptr);
void ButtonClosePushCallBack(void *ptr);
void LiftAnglePushCallBack(void *ptr);
Nextion component for page0
NexButton ButtonWeiter = NexButton(0, 1, "ButtonWeiter");
Nextion component for page1
NexText LiftAngle = NexText(1, 1, "LiftAngle");
NexButton ButtonMinus = NexButton(1, 2, "ButtonMinus");
NexButton ButtonPlus = NexButton(1, 3, "ButtonPlus");
NexButton ButtonEnter = NexButton(1, 4, "ButtonEnter");
Nextion component for page2
NexButton ButtonClose = NexButton(2, 1, "ButtonClose");
NexText Rate = NexText(2, 2, "Rate");
NexText Amplitude = NexText(2, 3, "Amplitude");
NexText BeatError = NexText(2, 4, "BeatError");
NexText BeatRate = NexText(2, 5, "BeatRate");
Nextion screens
NexPage zero = NexPage(0, 0, "zero");
NexPage one = NexPage(1, 0, "one");
NexPage two = NexPage(2, 0, "two");
Buffer zone of various variables
char buffer[100] = {0};
char buffer_Rate[10] = {0};
char buffer_Amplitude[10] = {0};
char buffer_BeatError[10] = {0};
char buffer_BeatRate[10] = {0};
char buffer_LiftAngle[10] = {0};
NexTouch *nex_listen_list[] =
&ButtonClose,
&ButtonEnter,
&ButtonPlus,
&ButtonMinus,
&ButtonWeiter,
&LiftAngle,
NULL
Lift Angle Function
dbSerialPrintln("LiftAnglePushCallBack");
LiftAngle.setText("52");
uint16_t len;
uint16_t number;
dbSerialPrintln("ButtonMinusPushCallBack");
memset(buffer, 0, sizeof(buffer));
LiftAngle.getText(buffer, sizeof(buffer));
number = atoi(buffer);
number -= 1;
itoa(number, buffer, 10);
LiftAngle.setText(buffer);
uint16_t len;
uint16_t number;
dbSerialPrintln("ButtonPlusPushCallBack");
number += 1;
Button Weiter Function
dbSerialPrintln("ButtonWeiterPushCallBack");
Serial.print("page one");
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
int time_elapsed = (start_time - end_time)/1000;
float Rate = (count/time_elapsed*10)*24*3600; //Beat rate per day
float BeatError = (start_time - end_time)/10; //Divided by 10 because we using 10 beats
int lift_time = (start_time-end_time)/3*1000; //Divided by 3 becuase we want to calculate time between first and third tick
float Amplitude = lift_angle / (2 * sin(180 * lift_time * Rate / 7200));
float BeatRate = 36600; //per hour
float Frequency = BeatRate / 3600;
dbSerialPrintln("ButtonEnterPushCallBack");
Serial.print("page two");
Serial.print("Rate.txt=");
Serial.print(Rate);
Serial.print("Amplitude.txt=");
Serial.print(Amplitude);
Serial.print("BeatError.txt=");
Serial.print(BeatError);
Serial.print("BeatRate.txt=");
Serial.print(BeatRate);
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
Button Close Function
dbSerialPrintln("ButtonClosePushCallBack");
Serial.write(0xff);
Serial.write(0xff);
Serial.write(0xff);
void setup(void)
nexInit();
Register all event callback function of all component.
LiftAngle.PushCallBack(LiftAnglePushCallBack);
ButtonPlus.attachPush(ButtonPlusPushCallBack);
ButtonMinus.attachPush(ButtonMinusPushCallBack);
ButtonEnter.attachPush(ButtonEnterPushCallBack);
ButtonClose.attachPush(ButtonClosePushCallBack);
ButtonWeiter.attachPush(ButtonWeiterPushCallBack);
dbSerialPrintln("Setup done");
void loop(void)
nexLoop(nex_listen_list);
