Read data from SD card, Transfer it using I2C, and show it on TV.
I'm working on a project that suppose to read text files from SD card, Transfer the first 3 lines (50 characters) in each file using I2C protocol to another arduino, which show these lines on tv screen.
The problem is with the transfer protocol and the TV part. Some data is transfered but it shows few, messy letters on the tv screen and i can't find what exactly is wrong.
The first arduino (SD read + data transfer) code is:
#include <SD.h>
#include <Wire.h>
File myFile;
int relay = 2;
char inputChar;
  Wire.begin();
  pinMode(relay, OUTPUT);
  pinMode(10, OUTPUT);
  SD.begin(4);
     for(int i=1;i<4;i++)
   Wire.beginTransmission(4);
   String temp = "Book";
   temp.concat(i);
   temp.concat(".txt");
   char filename[temp.length()+1];
   temp.toCharArray(filename, sizeof(filename));
   myFile=SD.open(filename);
   for (int j=1; j<50; j++) {
     inputChar = myFile.read();
     Wire.write(inputChar);
   Wire.endTransmission();
   long ontime =((0.1* myFile.size())-30);
   digitalWrite(relay,HIGH);
   delay(ontime);
   digitalWrite(relay, LOW);
   delay(5000);
   myFile.close();
The 2nd arduino (Data receive + TVOUT) code is:
#include <TVout.h>
#include <Wire.h>
TVout TV;
char tvMessage[49];
int index=0;
void setup ()
  Wire.begin(4);                // join i2c bus with address #4
  Wire.onReceive(receiveEvent); // register event
  TV.begin(_PAL);
void loop ()
  TV.clear_screen ();
  TV.print_str(0, 50, tvMessage);
  TV.delay ( 60 );
void receiveEvent(int howMany)
  while(0< Wire.available())
    tvMessage[index] = Wire.read();
    index++;
    if (index==49) {index=0;}
Any ideas?
Thanks.
CLICK THE MODIFY BUTTON TO EDIT YOUR POST.
We have a forum policy to ignore any post that starts with the salutation "Hey".
Did your test the transmit and recieve systems independently before linking them ? (do you get TV out with direct (not transmitted) input ?
Did you test your I2C connection with simple hard coded text transmissions before adding the SD card ?
Where's the schematic ? I can't see that far.
Each part of the system works fine as a standalone, but combining them together doesnt work.
Transmitting hard coded text is working fine, showing it on TV screen also works great.
If you want help troubleshooting a hardware problem you need to post a schematic.
