Read data from SMS header
Hy Everyone!
I’m with some trouble acquiring data from a received SMS header.
I want to extract data like the Number and the message from a received SMS.
I don’t know why the counters are not working correctly and why the password check always returns false.
All the help is welcome!
char ReceivedSMS[120] = "";
int RcvdCheck = 0;
int RcvdConf = 0;
int indice = 0;
int RcvdFim = 0;
char number[13];
int MsgLength = 0;
String strNumber = "";
char password[5] = "1234";
char extractedNumber[13];
char receivedTxt[25];
//          Functions
void Response()
  int count = 0;
  while (1)
    if (Serial1.available())
      char data = Serial1.read();
      if (data == 'K') {
        Serial.println("OK");
      if (data == 'R') {
        Serial.println("ERROR");
    count++;
    delay(10);
    if (count == 1000) {
      Serial.println("GSM OFFLINE");
void Config()
  Serial.println("START: ");
  Serial.print("Feedback Disable:           ");
  Serial1.print("ATE0\r");
  Response();
  Serial.print("GSM STATUS:                ");
  Serial1.print("AT\r");
  Response();
  Serial.print("SMS MODE:        ");
  Serial1.print("AT+CMGF=1\r");
  Response();
  Serial.print("SMS AS TEXT:    ");
  Serial1.print("AT+CNMI=1,2,0,0,0\r");
  Response();
  Serial.print("CLEAN SMS MEMORY:        ");
  Serial1.println("AT+CMGD=1,4\r");
  Response();
void ClearBuffers()
  strcpy(ReceivedSMS, "");
  strcpy(receivedTxt, "");
  RcvdCheck = 0;
  RcvdConf = 0;
  indice = 0;
  RcvdFim = 0;
  for (int i = 0; i < 13; i++)
    number[i] = ' ';
  MsgLength = 0;
void extractText()
  int contador = 0;
  int contadorVirgula = 0;
  int contadorMais = 0;
  char pelica = '"';
  char virgula = ',';
  char mais = '+';
  int a, b = 0;
          for (int x = 0; x < 120; x++)
                if (contador == 1)
                  extractedNumber[a] = ReceivedSMS[x];
                  a++;
                if (contador == 6)
                  receivedTxt[b] = ReceivedSMS[x];
                  Serial.print(receivedTxt[b]);
                  b++;
                if (ReceivedSMS[x] == pelica)
                  contador++;
  Serial.println("EXTRACTED:");
  extractedNumber[13]='\0';
  Serial.println(receivedTxt);
  Serial.println(extractedNumber);
  Serial.println("COUNTERS:");
  Serial.println(contador);
  Serial.println(contadorVirgula);
  Serial.println(contadorMais);
void RecSMS()
    if (data == '+') {
      RcvdCheck = 1;
    if ((data == 'C') && (RcvdCheck == 1)) {
      RcvdCheck = 2;
    if ((data == 'M') && (RcvdCheck == 2)) {
      RcvdCheck = 3;
    if ((data == 'T') && (RcvdCheck == 3)) {
      RcvdCheck = 4;
    if (RcvdCheck == 4) {
      RcvdConf = 1;
      RcvdCheck = 0;
    if (RcvdConf == 1)
      if (data == '\n') {
        RcvdFim++;
      if (RcvdFim == 3) {
        RcvdFim = 0;
      ReceivedSMS[indice] = data;
      indice++;
      if (RcvdFim == 2) {
        RcvdConf = 0;
        MsgLength = indice - 2;
        indice = 0;
      if (RcvdConf == 0)
        for (int x = 4; x < 17; x++)
          number[x - 4] = ReceivedSMS[x];
        strNumber = number;
        Serial.println(strNumber);
        Serial.println(ReceivedSMS);
        extractText();
        if (strstr(receivedTxt, password)!= NULL)
          Serial.println("PASSWORD VALIDATED");
          Serial.println("PASSWORD ERROR");
        Serial.println("");
        Serial.println("##################################################");
        Serial.println("");
        ClearBuffers();
  Serial1.begin(9600);
  Config();
  RecSMS();
  int a, b = 0;
What value is in a after this statement? If you said zero, you'd be wrong.
                  a++;
Write at some random location, before, in the middle of, or way past the end of the array and then increment the junk in a. NOT a good idea.
Your excessive number of blank lines
and your
piss-poor indenting
leave
a lot to be desired. Tools + Auto Format can help with the indenting. Delete the
excess blank lines yourself.
